Author Topic: block repair?  (Read 9881 times)
aarons428
block repair?
« on: February 12, 2012, 07:46:41 PM »
Can this block be repaired or is it just a BIG paper wieght?
65 f-100 swb
428 4v
c-6 trans wide ratio
3000 stall converter
torino front stub
latter bar style rear suspension w/air bags
11.96@110mph
Re: block repair?
« Reply #1 on: February 12, 2012, 08:27:15 PM »
That can be fixed, but the question will be is it worth the cost.  What kind of block is it?  If its a 428, it would probably worth the repair.  If it's a 390, I think you'd be better off getting another one.
To fix that you will need to find a cast iron welding shop, get a patch welded in, and then get the block remachined.  The welding operation will warp the block surfaces, so it will probably have to have the oil pan rail re-machined and also the main saddle align-honed.
aarons428
Re: block repair?
« Reply #2 on: February 12, 2012, 08:54:55 PM »
It is a virgin bore 428 I was hoping it could be repaired thanks Jay.
65 f-100 swb
428 4v
torino front stub
11.96@110mph
Re: block repair?
« Reply #3 on: February 12, 2012, 08:57:24 PM »
Yep, that one is definitely worth repairing.  Good luck with the block - Jay
hotrodfeguy
Re: block repair?
« Reply #4 on: February 14, 2012, 12:11:44 AM »
Yes 428's and crossbolts are worth doing. I have three in my shop right now I have to weld up. I repair them, what is your location?
aarons428
Re: block repair?
« Reply #5 on: February 14, 2012, 09:50:20 PM »
I am in Norfolk Nebraska
65 f-100 swb
428 4v
torino front stub
11.96@110mph
hotrodfeguy
Re: block repair?
« Reply #6 on: February 19, 2012, 02:46:51 PM »
Prolly close enough to do. I am in Green Bay, I am also headed to Iowa soon for some other parts.
aarons428
Re: block repair?
« Reply #7 on: February 19, 2012, 03:22:35 PM »
What part of iowa and what would be aprox price to fix. How often do u get to iowa.
65 f-100 swb
428 4v
torino front stub
11.96@110mph
hotrodfeguy
Re: block repair?
« Reply #8 on: February 20, 2012, 04:31:11 PM »
send me a e-mail hotrodfeguy@ hotmail I dont want to clutter the board or PO the MOD :)
hotrodfeguy
Re: block repair?
« Reply #9 on: March 09, 2012, 10:29:46 AM »
I do have a donor block thats already chopped up that I could use again for that one. And that would be a pretty easy fix/repair. I also purchased a new welder and makes for a much better weld now.
