Author Topic: Lost oil pressure  (Read 24418 times)
Re: Lost oil pressure
« Reply #15 on: August 20, 2015, 06:21:18 AM »
I feel like I'm in a Loctite bidding war.....anybody using green?  ;)
« Reply #16 on: August 20, 2015, 06:38:21 AM »
We have usd ARP with red loctite for pickup tube and pump to block. The pump cover plate I like to use allen bolts and drill for lock wire. The standard style bolts with lock washers and blue loctite should work fine also. Just be sure with the loctite that the threads are nice and clean and dry before applying. ;)
ToddK
« Reply #17 on: August 20, 2015, 06:42:13 AM »
Red Loctite it shall be.
« Reply #18 on: August 20, 2015, 07:31:40 AM »
Glad you found the problem and it was a simple one!
« Reply #19 on: August 20, 2015, 07:58:40 AM »
May want to pop a couple bearing caps just to ease your mind.
RJP
« Reply #20 on: August 20, 2015, 12:00:40 PM »
Red Loc-tite here...
X2...If yer gonna use the stuff..use the strongest stuff available.
« Reply #21 on: August 20, 2015, 12:12:52 PM »
I do know that red tastes better than blue....
RJP
« Reply #22 on: August 20, 2015, 12:15:04 PM »
I don't think I want to know how you know that. :P
« Reply #23 on: August 20, 2015, 01:27:37 PM »
Although the filter was clean the bearings can be
damaged.Without pick up the pump could not
pump any oil with metal shavings in to the filter
so check atleast the bearing most downstream
from the pump
fastback 427
« Reply #24 on: August 20, 2015, 02:46:22 PM »
The red does taste better, but it gives me the $hits ;D
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
« Reply #25 on: August 20, 2015, 03:28:56 PM »
The green is badass.  Heat won't touch that stuff.  You need explosives!  :)
« Reply #26 on: August 20, 2015, 03:32:02 PM »
I didn't know we had Loctite drinkers here, I thought we were limited to engine BraKleen inhalers and silicone sniffers.  This is truly an equal opportunity forum  ;D
ToddK
« Reply #27 on: August 20, 2015, 04:53:36 PM »
I will pull the 4 and 8 rod caps and check the bearings before I put things back together.
« Last Edit: August 21, 2015, 07:57:57 AM by ToddK »
« Reply #28 on: August 20, 2015, 07:40:48 PM »
You forgot the all important Cam2, Supreme, AV gas, or other fuels and flammable liquids. ;)
Personally, I like a little anti-seize on my toast.....
« Reply #29 on: August 20, 2015, 08:06:06 PM »
Hey, let's not forget the queen of all inhalable solvents, lacquer thinner! Gonna take you higher...higher! LOL
