Author Topic: FE in a lighweight car  (Read 15134 times)
Re: FE in a lighweight car
« Reply #15 on: June 23, 2015, 10:51:47 PM »
« Last Edit: June 23, 2015, 10:53:29 PM by fekbmax »
MeanGene
« Reply #16 on: June 23, 2015, 11:04:21 PM »
Workin' on it- slowly  :P
mike7570
« Reply #17 on: June 24, 2015, 04:01:17 PM »
Some pics of my '69 Mustang - could get to 2500lb with driver.
« Last Edit: June 24, 2015, 04:10:24 PM by mike7570 »
« Reply #18 on: June 24, 2015, 09:48:54 PM »
69 fastback. Home built tube car. Mild steel. 7.50 certification.  444cid FE. Jerico 4 speed clutchless, fiberglass front end, doors, deck lid. All home built by me.  Building New engine . .. comming soon..
« Last Edit: May 29, 2016, 07:56:00 PM by fekbmax »
« Reply #19 on: June 25, 2015, 06:06:26 AM »
Nice!
What type of clutch do you use?
« Reply #20 on: June 25, 2015, 09:25:38 AM »
As it sits right there I was using a hays mark 12 , 3 finger with a single 5135 disk.
Now I have a brand new Bonafanti billet aluminum 6 finger single disk set up that I'm thinking about trying once I get the new engine back together and the car back up and running. I may start with the hays. First though just cause I'm most familiar with it.
« Reply #21 on: June 25, 2015, 07:45:55 PM »
More questions... ::)
What type of bell do you use and have you tired to fit the Bonafanti in?
« Reply #22 on: June 25, 2015, 08:43:44 PM »
quote author=ScotiaFE link=topic=2805.msg28166#msg28166 date=1435279555]
Ask anything you like,
I use a old style lakewood 7" steel can I got back in the early 90's. I cut an adjustment window in it and made a cover and it turned out as good as factory.  The bonafanti single disk will fit. I have had it mocked up and the only change i had to make was going to a shorter (thinner) throwout bearing. A Duel disk will not fit ofcourse.
BigBlockFE
« Reply #23 on: June 26, 2015, 10:11:09 PM »
My car has a 4 inch tube chassis, convertible...
