FE Technical Forum
Ford FE oil pump
Topic: Ford FE oil pump (Read 4372 times)
Skip1951
Newbie
Ford FE oil pump
May 25, 2015, 11:45:42 AM »
I would like to know if anyone can tell me where I can get a replacement Welch Plug and a Higher Pressure Relief Spring for a Ford FE Oil Pump.
fairlanegt427
Full Member
64 falcon 482 pond motor/ 65 comet 428
Re: Ford FE oil pump
Reply #1 on:
May 25, 2015, 11:59:22 AM »
precisionoilpumps.com they have everything you need and they are not very expensive. hope it helps
Skip1951
Newbie
Reply #2 on:
May 25, 2015, 03:33:48 PM »
Thanks for the help, will check it out.
fairlanegt427
Full Member
Reply #3 on:
May 26, 2015, 07:19:08 AM »
if i remember right that oil pressure relief spring was 35 bucks. or along those lines.
Howie
Reply #4 on:
May 26, 2015, 07:42:12 AM »
You want the blue spring.
FE Technical Forum
Ford FE oil pump
