Author Topic: 390 overheating at idle  (Read 19629 times)
Re: 390 overheating at idle
« Reply #15 on: July 29, 2015, 01:52:57 PM »
When I bought my '66 Fairlane in '97 it was completely stock, but pretty worn.  When I drove it the 40 or so miles home I noticed the fan made a lot of noise... Since it was a factory air car I didn't think too much about it; those cars came with a 7-blade fan.  A few weeks later I started working on the front of the engine to replace belts, hoses, etc.  When I got the fan off I noticed the word FRONT stamped on the fan hub was facing the rear!  After putting it back together correctly that fan was a lot quieter!
Bruce
FirstEliminator
« Reply #16 on: July 29, 2015, 02:03:48 PM »
   The fan on backwards won't push air backwards as the angle is still the same, it will still pull towards the engine. It's the design in the curvature of the blade that is disrupted and really reduces efficiency.  You would need a reverse rotation fan to actually push air. So, on backwards it kinda works. On frontwards it actually works.
  A friend of mine with a 64 Country Squire  accidentally installed a reverse rotation fan and it blew a lot of hot air out the grill. Changed the fan and it didn't over heat within 10 minutes.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
