Author Topic: Power level with iron heads  (Read 31179 times)
bartlett
Re: Power level with iron heads
« Reply #30 on: January 20, 2015, 10:00:30 AM »
just build a 500/550 or so motor and slap a plate on it like I did.. a 200 shot will keep you entertained ... :o
Ean R
« Reply #31 on: January 20, 2015, 10:16:33 AM »
Ross, fast and reliable is exactly what I want.  I really want the best of both worlds. Cruise with the mrs and kids, coffee in hand then throw it out the window and hope hers isn't too hot when it gets flung back all over her as I launch it at 6000 rpm from the lights while dragging off the chev that has pulled up next to me!
You know what I mean.
I know it's a compromise but I don't want a big loping  highway cruiser although I want the reliability of one. You say you have 600hp in a very streetable form, 600 is 600 right? any way it's delivered and if it does it without overheating and stalling in traffic every 5 minutes then that's the engine I'm after BUT can I have that with an extra serve of nasty?
Simple version: in its 427 form the engine idled at about 800 was really lumpy and only sounded meaner the more revs you gave it and although I don't think it had been driven in 10 or so years and was in need of a rebuild when I got it, was surprisingly fast. The first 20 minutes  after it arrived from the USA was spent terrorising an elderly gent with his young wife in a Lambhorgini the full length of Canning HWY (Todd, you'll know where I'm talking about)
 Considering I've owned severel 351 clevo vehicles admittedly none of them had major work done to them, the side oiler was a whole new experience.
Can I have the same "personality" as the 427 but with more cubes and HP and considering most of the engine will be brand new, decent reliability?
I don't want to spin it to 8000rpm but to have the ability to go to 7000rpm without fear of it exploding is what I'm after.
Bud, thanks for the info on the headers. Do you know if they bite as hard as Hookers when you fit them?
Todd, I'll give you a call this week, would really appreciate a ride in your Galaxy.
Ean Rinaldi
66 Fairlane 500
427 side oiler
Ean R
« Reply #32 on: January 20, 2015, 10:19:25 AM »
Stop it ;D ;D
Ean Rinaldi
66 Fairlane 500
427 side oiler
bill_396
« Reply #33 on: January 20, 2015, 12:55:26 PM »
Ean, Blair works with REF too. He is having them build a set for me using custom flanges he sourced to mate up to the BT heads he did for me. He also provided me with a very work over Dominator flanged Victor to match up with my BT's intake ports that are moved over and apparently raised from the stock location. My application did require offset rockers and lifters but I believe similar results can be had with Pro-Ports without so much weld and epoxy.
Garyford
« Reply #34 on: January 20, 2015, 02:20:46 PM »
Ean,
what you are hearing might be conventional approaches, however; amongst some of the FE experts there are so many exceptions that with enough tuning and practice anything seems possible.
Time to hear from some of the BC (Canada) and other guys who run faster that thought possible with solid lifter cams, iron heads etc.  If getting stuff in Australia is a challenge, their approach might be worth considering.
« Reply #35 on: January 20, 2015, 02:30:46 PM »
OK, so my setup has been together since 2006, EFI since 2009?....I forgot...it is a 489 inch 10.7:1 FE, very careful blueprinting, Sequential Port Injection based off a 89-93 Ford EEC-IV, 1400 cfm dry throttle body, ported Victor intake, ported Edelbrock heads, started life as KC Stage 2 then worked over pretty well.  Cam is an Erson solid flat tappet grind with discontinued Comp lightweight lifters, relatively mild cam for a 489, but run about as tight lashed as I can and still have the valves stay closed (that happened after the EFI, with the carb it was a little more rowdy, so I ran them loose).  Cam specs are 242/246, .595 lift, but measured at the valve it acts a bit more aggressive lashed at .012/.014 vice .028 Erson spec and the adjusters about as deep as I would gamble with to get the valves off the seat quickly.  The power is made in the heads and intake though
This cam can chug away at 1500 in 5th with EFI, with the carb it was 1800-1900, or shift at 6500.  It sure wouldn't blow up at 7000+, but it would be a waste spinning it that high.  When it was carbed, it'd do the same thing, but was probably 30 hp less (WAG) .   Keep in mind though, say it was 560 with the old carb/RPM intake combo, standing on it getting on the highway in 3rd would put me in a smoky drift without hitting the clutch, just a roll on.  So what I am trying to say to is, ignore the numbers for the most part and build for the use.  I also try to err with "more head" versus "more cam", especially in something that will be driven for miles.
FYI it idled at 1100 with the 1000 Holley and ported RPM intake, with the SEFI it idles at 900, I could go lower but I like oil being thrown around to keep the cam alive
IMHO, your combo is begging for a big hyd roller build with a serious set of heads and intake, you'll get the miles and power without hitting 7000.  Remember, this is NOT a Clevor, and FE can scare you from idle to redline but you don't need to build it for the big top end charge like a Cleveland headed motor, nor does it need a 6000 rpm launch.  Long runners and smaller intake port cross section don't need or want it, these engines work the whole curve.
I may have missed it, but does your side oiler have oil to the lifters?
ON EDIT - I think you could actually do what you want with iron heads, and maybe even use your existing cam, especially since it isn't a racer that needs to win rounds.  However, building alum heads and selling the iron, may be a better value in the long run.  Additionally, until someone figures out exactly what your cam specs are, it's tough to plan the entire package.
« Last Edit: January 20, 2015, 02:35:00 PM by My427stang »
bn69stang
« Reply #36 on: January 20, 2015, 09:20:38 PM »
Listen to Ross , and remember you are building a street car first and formost .. for the street you dont have to spin it to 7,000  .  6000 to 6500 at most .. A set of Blair s  pro ports or BBM or Survival heads and a head that flows from 400 inchs of lift to 600 in the 275 s to 300 s .. If you want to put it together , and drive it and not ever mess with it and make 580 -600 , go hydraulic roller and a sound bottom end . For what its worth when i first joined this form , i was told to spend the money on the valve train and head work . And as Ross said you dont have to spin the motor to 7000 rpm . IMO build a strong mid range motor 2000 - 6000 and gear it right and let it rip , and enjoy it ..Bud
Ean R
« Reply #37 on: January 20, 2015, 11:14:49 PM »
You can't blame me for getting excited and wanting a 8000 rpm 800hp monster but this is why I joined this forum.
Ross, you are right, I'm used to small blocks and being underwhelmed by them  so I'm probably shooting a bit high with this engine.
Bud has summed it up pretty well perfectly with regards to what I want from the car/engine with the only problem being the block isn't drilled for oil to the lifters ( as far as I'm aware).Hence the reason I'm leaning towards a solid cam.
 Other things like oil holes have been chamfered and ramped etc on the main bearings and where the oil filter mounts. When I had the exhaust fixed at a local shop that specialises in old style cars, very few FE though, the bloke said it had an aftermarket cam but I don't think he'd ever seen or heard a 427 before.
The iron heads I had new springs,chrome moly retainers, the ports blended and valve seat grind.
According to Luigi the Head man the heads had already had bigger Manley valves and hardened valve seats for unleaded?  I had this done after blowing a head gasket and blew a second one a month later hence the rebuild.
So I think the block has been prepped before and the little mods I've read about eg the oil holes chamfered etc have been done which  makes me think Bud is right and to spend the money on the heads and valve train.
The car has Holman Moody stickers on the windows but most fairlanes probably do.
I've been in contact with Blair Patrick and I'll leave it in his hands to come up with a combination that works, although he is already breaking my heart by trying to convince me a RPM would suit better  than a Victor.
Victors "look meaner" though.
Ean Rinaldi
66 Fairlane 500
427 side oiler
« Reply #38 on: January 21, 2015, 07:23:22 AM »
My Victor works well, but I also have the benefit of EFI keeping most of the runner dry and then being able to control injector timing.  The RPM will be a better match
Nothing wrong with a solid flat tappet, you just need to take a few more precautions.  Blair will steer you right
bn69stang
« Reply #39 on: January 21, 2015, 05:58:23 PM »
Ross is right on the money , and a set of Blairs pro ports would be the way to go if in the budget and have him pick a cam , and when your project is done and you actually drive it , you ll be happy and the look of the intake  wont even enter your mind .. Bud
« Reply #40 on: January 22, 2015, 06:31:39 AM »
Have you considered a clutch pedal?
The converter is very consistent at the line, but out on the highway an extra gear or two
really changes the giddy up.
Even a modest FE will shred pretty much any street tire with proper or improper clutch pedal manipulation.
The Fairlane has somewhat tire limiting holes so traction will always be an issue with a HP FE.
And it sounds way kooler than "slush box".
Ean R
« Reply #41 on: January 25, 2015, 12:46:56 PM »
RPM VICTOR SIDEWINDER which it has now, don't care as long as it works!
I'm pretty sure it's not drilled for oil to the lifters so flat tappet is only option plus they sound great
A manual? I've already bought the slush and I reckon a fairlane is a pretty big boat to "row"
It's 40c in summer here you blokes, compulsory one arm out the open window.
I'll post photos if I can work it out.
Anyone recommend a flat tappet cam . . Would like to keep the same style" but to suit the bigger cubes,  rev master 306 iskenderen  Lx74 is stamped on one end of the cam in it now?
Can't find anything on the net about this cam.
Ean Rinaldi
66 Fairlane 500
427 side oiler
« Reply #42 on: January 25, 2015, 01:08:25 PM »
Do you have the ability to measure it yourself?  An hour with a degree wheel would tell you exactly what it is, it may be a decent match
Ean R
« Reply #43 on: January 25, 2015, 01:13:33 PM »
Ross mate, I'm not even going to embarrass myself with a reply.
I pulled and stripped the engine undoing bolts and nuts is about my limit and I'm not real flash at that
Beautiful Mustang by the way
« Last Edit: January 25, 2015, 01:15:14 PM by Ean R »
Ean Rinaldi
66 Fairlane 500
427 side oiler
« Reply #44 on: January 25, 2015, 01:44:20 PM »
Thanks for the compliment on the car and that was a funny reply, but appreciate the honestly.
A machine shop can tell you, they can either mock the cam up in a block and measure, do it on V-blocks on the bench, or some higher end shops have a tool, like the CamDoctor, which does it electronically by measuring the lobes.
If your machinist is relatively affordable, have him look at the cam for condition, and if his price is good, measure it.  In the end, even if you don't use it, you'll have the data to sell it
I'll dig around and see what I can find
