Author Topic: Electric Water Pump Question ?  (Read 8828 times)
garyv
« on: December 10, 2014, 09:48:23 AM »
Does anyone know how much longer and electric water pump is than a stock Edelbrock pump.
Thinking about using one but not sure if I will have enough room to clear the electric fan/radiator.
Appreciate any info.
garyv
Re: Electric Water Pump Question ?
« Reply #1 on: December 10, 2014, 09:56:32 AM »
The CVR universal high volume pump plus my adapters is almost identical in length to a factory or Edelbrock pump; I think they measure within 1/8" of each other.  I imagine that most of the electric water pumps for FEs are about the same as that...
garyv
« Reply #2 on: December 10, 2014, 10:47:16 AM »
Thanks Jay
appreciate the info.
garyv
« Reply #3 on: December 23, 2014, 06:07:15 AM »
TADA!
Nice pieces Jay....thanks a bunch.
XR7
« Reply #4 on: December 23, 2014, 04:35:26 PM »
What (who makes it) bracket is that on the vacuum pump? GZ?
« Reply #5 on: December 23, 2014, 08:10:47 PM »
It's a GZ bracket....
KMcCullah
« Reply #6 on: December 24, 2014, 12:22:20 PM »
Wow I just compared the CVS-8000 to the Meziere. The CVS flows more GPM, draws less current and cost hundreds less. Win, win, win! Jay really has hit a homerun with his water pump adaptors.
Kevin McCullah
fairlanegt427
« Reply #7 on: December 26, 2014, 10:42:23 AM »
right away i noticed the vacuum pump bracket bracket unrelated to this subject in this looby.  what else caught my eye was the mandrel also,  is that a gz mandrel  also?  reason being is that pretty much every vacuum pump company i talk to doesnt make one for the fe. the ones that i have found sit in the counterbore of the sfi dampers which on an fe they arent counterbored,  for instance a gm motor the damper bolt sits in a counterbore on these aftermarket dampers the fe bolt and thick washer sit flush theirs no counterbore.  so does that mandrel just bolt onto the 3 bolts on the front of the damper?
fairlanegt427
« Reply #8 on: December 26, 2014, 10:44:40 AM »
one other thing i just seen also.  how far in front of the waterpump does the mandrel stick out?
« Reply #9 on: December 27, 2014, 09:13:48 PM »
GZ makes the whole deal for the FE.....sweet setup.
I can measure to see how far the mandrel sticks out, but for reference, that pulley behind the front pulley on the mandrel was for the water pump/alternator.  That will give you a sense of depth on it.
fairlanegt427
« Reply #10 on: December 28, 2014, 11:35:53 AM »
so does the mandrel just bolt onto the 3 bolts of the damper?  also is that a gz mandrel? or some other company?
« Reply #11 on: December 28, 2014, 01:15:02 PM »
GZ makes the whole thing.....
The mandrel bolts straight to the crank snout and is also pinned so it can't spin.
fairlanegt427
« Reply #12 on: December 29, 2014, 10:25:35 AM »
ok im gonna call gz and get me one. thanks for the help.
