Author Topic: Rear end yoke.  (Read 4027 times)
bn69stang
Rear end yoke.
« on: December 07, 2014, 05:15:35 PM »
I am gathering all the parts i need to do the center section setup , and my question is matching the yoke thats currently under the car so my drive line length stays the same . It measures  right at 3.5 inchs from dust cover to the center of the u joint , would that be the long yoke  ? ..Bud
bn69stang
Re: Rear end yoke.
« Reply #1 on: December 07, 2014, 06:14:08 PM »
I guess i should add  that the third member in the car now is a factory n case with 3.50 s and a trac loc , and daytona pinion support and has the collar mounted with the pinion support bolts , with a rubber stop on the top . I want to keep it all together , and not sure what it came out of . Thanks  Bud
