Author Topic: Let the cutting begin......  (Read 44429 times)
Re: Let the cutting begin......
« Reply #30 on: December 04, 2014, 09:09:24 AM »
So what does Heo win...a pair of LeMans valve covers? LOL!
65er
« Reply #31 on: December 04, 2014, 09:50:01 AM »
bag-o-chips, lol
Cool project, I'll be interested in seeing it develop too.
-Wade
« Reply #32 on: December 04, 2014, 09:53:57 AM »
I am making a hell of a lot of chips. This be one side. Its gunna take me a day to clean up before the next operation!!
Reminds me of a quote from Lil' John Buttera, published in Hot Rod many years ago.
HR:  "How do you machine a billet aluminum side mirror?"
Buttera:  "You just start with a big chunk of aluminum and machine away everything that doesn't look like a mirror!"
« Reply #33 on: December 04, 2014, 02:30:47 PM »
An all inclusive vacation in Australia would be nice ;D ;D ;D ;D
66FAIRLANE
  • Andy
« Reply #34 on: December 14, 2014, 07:00:21 PM »
Anyone else think these holes might be a bit small to feed an angry FE? That's a 600 gasket by the way. Holes at 27/32.
Good thing I ordered me one of these...
http://www.ebay.com.au/itm/New-MT3-M12-Morse-taper-50MM-Boring-head-9pcs-12mm-boring-carbide-tips-box-/161516680832?pt=LH_DefaultDomain_15&hash=item259b24f680
« Last Edit: January 12, 2015, 05:13:22 AM by 66FAIRLANE »
66FAIRLANE
  • Andy
« Reply #35 on: January 12, 2015, 05:13:00 AM »
It was a humid one here today. 8pm it was 28C and 70% humidity in my shed and the only way I had to cut this in half was a hacksaw. I was saturated with sweat. I now have the holes at 1-1/16. Not the prettiest but the mill will fix that and the cheap Chinese boring head has arrived.
66FAIRLANE
  • Andy
« Reply #36 on: January 13, 2015, 05:11:57 PM »
A little more progress last night. Tidied up my sublime hacksawing and took the two TB's down to the same height.
Then spotted through the base plates and drilled and tapped to accept.
Base plate bolted on. Have to pick up the rough throat holes and whack em through the base plate. I am at 1-1/16 at the moment. I have a 1-1/4 drill but I can't hold it as it is MT4. I might turn it down to MT3 and if that works from there I can use the boring head and sneak up on 1-9/16.
« Last Edit: January 13, 2015, 11:38:07 PM by 66FAIRLANE »
66FAIRLANE
  • Andy
« Reply #37 on: January 29, 2015, 05:37:20 PM »
Well, this is going to require something I don't have much of (and can't buy on ebay), patience!
I need to take out 1/2" with the boring head! Ah well....suppose I have the time. Did one hole last night and it came up pretty good. Now it is set up I can just do one whenever I feel like it.
Didn't really bother about exact hole positions when I roughed out the holes. Its a bit more critical now.
Clocking it up square
Boring head about to go in
One hole done
66FAIRLANE
  • Andy
« Reply #38 on: February 01, 2015, 05:26:04 PM »
Spreadbore EFI anyone?
Didn't think so
Only done one at this stage and will probably concentrate on it until finished. Next thing is disassemble and rough cut the corners off of the top and clock up in a 4 jaw chuck (hope it fits!) and turn the air cleaner seat. Then bore holes in base plate for throttle shafts.
66FAIRLANE
  • Andy
« Reply #39 on: February 05, 2015, 05:46:48 PM »
Chucked up in the 4 jaw and starting to look like a throttle body.
ToddK
« Reply #40 on: February 05, 2015, 09:55:31 PM »
Probably be easier to buy an off-the-shelf unit, but nowhere near as much fun. ;)
Definitely watching to see how this turns out.
66FAIRLANE
  • Andy
« Reply #41 on: February 05, 2015, 10:07:04 PM »
Definitely, but it gets me out of the house and having a quiet tipple in the shed. Just always wanted to make one for some reason. Now I'm making two.
cobracammer
« Reply #42 on: February 06, 2015, 10:47:43 AM »
That's awesome!  I get such a rise out of people taking a chunk of metal and machining out a custom piece.  Keep on Keeping on!
Jason
66FAIRLANE
  • Andy
« Reply #43 on: February 12, 2015, 04:49:44 PM »
A little more progress.
Decided to put a 'lead in' on the throats and settled at 10 degrees. Had to clock up each one in my 4 jaw chuck to get centre and then slowly does it as I was only holding with 2 jaws. The body was offset so far that one of the jaws would hit another before contacting the job.
Clocking up
Slowly does it
Two done for comparison
All 4 done
Now to work out how to bore a long straight hole for the throttle shafts. Hmmmm.............
« Reply #44 on: February 12, 2015, 07:23:39 PM »
Nice job.There is special drills for long holes.Gun drills
but.....they dont work there since you got the throtle
bore there...If you bore undersize and index carefully
and use a loong reamer with the right size
