Author Topic: 390 pump gas deal... 1976 F100 aka "The Mistress"  (Read 42940 times)
bluef100fe
« on: December 05, 2011, 08:15:58 PM »
Build consists of 4.085 bore, 3.784 stroke,10.6 to 1 TRW flat tops, Hastings rings. C4AE-G heads with my valve job and port work and stock 2.03/1.56 valves. Holley strip dominator intake with some rubbing, 2 inches of carb spacer under the Quick Fuel 800 CFM carb. 14 by 6 air cleaner. Cam is a solid flat tappet from Oregon Cams. Harland Sharp rockers with P.O.P shafts and stands. Header are 2 by 36 with 3.5 collectors. This combo has gone a best of 12.35 @ 106 in my 3900 lb. truck this fall after about 7000 street miles and being bracket raced for one season.
Dyno sheet:
Dyno video:
https://www.facebook.com/ladowski/videos/2559498261187/
« Last Edit: April 29, 2017, 04:22:44 AM by bluef100fe »
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
Re: 390 pump gas deal
« Reply #1 on: December 05, 2011, 08:34:07 PM »
A healthy 390.
No details though?
bluef100fe
« Reply #2 on: December 05, 2011, 08:39:21 PM »
Sorry I'm trying the Internet Explorer I'm using keeps crashing on this site for some reason. I think I got most of it now.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #3 on: December 05, 2011, 11:02:18 PM »
Sounds like a solid combo.
I see your oil pressure is steady at 84 psi, which is good.
Which oil pump and spring are you using?
Do you remember your bearing clearances?
Just gleaning data. Thanks.
« Reply #4 on: December 05, 2011, 11:24:01 PM »
Cody, are you sure the intake is a Holley STRIP Dominator? I have had Street Dominators, but I didn`t think Holley made any FE Strip Dominators.
« Reply #5 on: December 06, 2011, 09:46:38 AM »
Hey Rory, good to see you over here!
« Reply #6 on: December 06, 2011, 12:44:00 PM »
I think it must be a Street Dominator, since they never made a Strip Dominator for the FE.  Maybe Cody sent it to Joe Craine for porting and now its a Strip Dominator  :D
bluef100fe
« Reply #7 on: December 06, 2011, 01:28:50 PM »
I will take a look at it tonight now I'm second guessing myself. Hey Jay I thought Joe retired?
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #8 on: December 06, 2011, 02:15:24 PM »
I think he did, Cody, several months ago.  Great to see you on the board, by the way...
rcodecj
« Reply #9 on: December 06, 2011, 03:29:48 PM »
And I'm still kicking myself in the butt for not getting my PI intake to Joe Craine while he was still porting intakes.
GUH!  :(
« Last Edit: December 06, 2011, 03:33:55 PM by rcodecj »
Joe-jdc
« Reply #10 on: December 06, 2011, 04:42:55 PM »
Guys: I will try to help forum members on a limited basis with intake manifolds, but I am trying to keep it at a minimum.  I still have not gotten to a couple of my own projects.  I have been helping a couple of my old customers with really neat combinations, and it has been fun.(270-280cfm through a 1.94 intake valve.)  If you are not in a hurry, then e-mail me with your need, and I will see what is possible.  Joe-JDC.
rcodecj
« Reply #11 on: December 06, 2011, 06:29:12 PM »
Joe,
I emailed you at your ******** at  swbell.net email. Let me know if that's not up to date.
Thank you.
bluef100fe
« Reply #12 on: December 06, 2011, 07:13:32 PM »
Well you guys are right. It's a street dominator intake.  I'm running a m57hv pump with the supplied spring from melling. Front sump pan with 6 quarts oil. Oil clearances are in the. 0025-.0030 range as I reused the rod and main bearings last time it was apart. Running 5w50 oil. These engine never had that kind of pressure in the truck.  Probably due to low temperatures on the dyno.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #13 on: December 06, 2011, 10:48:27 PM »
I did notice that the water temp was pretty low.
Might have even put the numbers a tad higher if it was a bit warmer.
The oil would have been pretty thick.
« Reply #14 on: December 06, 2011, 11:58:41 PM »
Actually, lower water temperatures will result in higher horsepower numbers than higher water temperatures.  The reason is that the lower temps keep the intake charge cooler, and make the engine more volumetrically efficient.  Less heating of the air/fuel charge in the intake tract, basically.  Thicker oil will tend to reduce horsepower, but the affect of the water temperature is much larger than the effect of the oil temperature.  This is why you'll see a lot of racers icing down their intake manifold or flushing the cooling system with cold water before a pass.  If you can manage it, cold water and hot oil will give you the best horsepower numbers on most conventional engines.
« Reply #15 on: December 07, 2011, 12:11:23 AM »
We have seen two Dyno sheets this week.
On one it shows .88 Inertia Factor and the other shows .68 Inertia Factor.
How much would this effect the big number everyone wants to see?
« Reply #16 on: December 07, 2011, 09:19:51 AM »
Howie, that is a really good question, and I don't know the answer.  This relates to the way the DTS dynos function; Superflows don't have an equivalent number.  Maybe Barry or Blair or someone who knows something about DTS dynos will chime in on this one.  I'll ask when I have a chance - Jay
bluef100fe
« Reply #17 on: May 14, 2012, 10:15:01 AM »
Wanted to add some interesting info I learned at the  race track track last weekend... story goes my friend needed a engine to borrow for his 1964 falcon drag car for a couple of weeks because his edelbrock headed 428 pulled a rocker stud insert out of its head. So my trucks 390 that I dynoed last fall was just sitting on the floor next to my truck yet so we stuffed it in his drag car so he could stay in the points chase. I figured his 3100-3200 lb. Car would go 11.60-11.40's in good air. Well we only made 2 qualifying passes and it ran better than we expected car went 11.17 @ 118 mph and 11.16 @ 118 and change. First round eliminations it went 11.18 @ 118 mph and he spun the tires 2nd round eliminations and went 11.29. Only changes from the dyno were using my friends biggs 950 instead of my custom 800 quick fuel and using the homemade oil pan that fits the car.. moral of the story is I guess I need to build a race car if I want to go fast cheap lol.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #18 on: May 14, 2012, 02:44:11 PM »
Great results, Cody.  You need to find a 3/4 scale pickup for the race track  :D
bluef100fe
« Reply #19 on: May 14, 2012, 07:15:55 PM »
Pretty sure this thing would break into the 10's if we put the 4.56's in the car and get after the leave rpm which was only 3800 rpm last weekend. What does the moroso hp calculator say this about this combo?
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #20 on: May 14, 2012, 10:49:24 PM »
If it's 3200 pounds with the driver the Moroso dream wheel says just over 400 HP.  If it is 3400 with driver, about 430.
bluef100fe
« Reply #21 on: May 15, 2012, 05:48:35 AM »
Thanks jay..... im still not done looking for more power lol
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
65er
« Reply #22 on: June 29, 2012, 09:43:19 AM »
  It's going to take a few more HP to get my Galaxie in the 12's but from what you've demonstrated here I should be able to pull it off without having to go entirely crazy.
Very nice and very encouraging Cody, thanks for showing me this!
-Wade
bluef100fe
« Reply #23 on: June 29, 2012, 11:48:50 AM »
Your welcome Wade. I know your car is a little heavier than my truck but I still don't see any reason you can't run mid to upper 12's with your car. I figure your aerodynamic advantage cancels out any weight difference there is. Get er done...
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #24 on: February 14, 2013, 12:09:02 PM »
Bumping this up for the heck of it... Hopefully some new dyno numbers to post in a couple months... Think I might have found some more hp lol...
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
fe66comet
« Reply #25 on: February 14, 2013, 01:15:54 PM »
Here is my street dominator..
I did.not end up using this intake but went dual quads. I have been squeezing every HP out of my build I can from anywhere I can so I am hoping for some nice numbers from my 445. I started the assembly or the bottom end yesterday at my sisters heated garage and moving along.
« Last Edit: February 16, 2013, 01:24:12 PM by fe66comet »
65er
« Reply #26 on: February 16, 2013, 07:22:24 AM »
What specs on that Oregon Cam Cody?  And what are you doing to find you a few more HP?
And I think I saw a video of your truck on the dragstrip once but I can't find it anymore.  Can you post a link for the vid?  :)
« Last Edit: February 16, 2013, 07:53:16 AM by 65er »
-Wade
bluef100fe
« Reply #27 on: February 16, 2013, 08:43:34 AM »
I will try to post a vid again.... I think I have one on my facebook page. I see the links in this thread seem to just take me look to my homepage now not my dyno vid and dyno sheet. Wonder what's up with that?
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
65er
« Reply #28 on: February 16, 2013, 09:48:08 AM »
Yeah, that's what I saw on your links just this morning. They dyno and results sheet.  Maybe if you're logged in it just takes you home.
-Wade
bluef100fe
« Reply #29 on: February 25, 2013, 05:39:30 PM »
Here is a link to a short video I made from two years ago. Haven't gotten any better video as of yet. Hope this works.
http://www.429-460.com/t10863-launch-video-of-my-f100-the-other-weekend-made-some-progress
enjoy.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #30 on: April 11, 2013, 10:25:38 AM »
bump for some 2012 video of my 390 at the strip.. I think the commentary is on the night video is funny... enjoy
http://www.youtube.com/watch?v=GlBtyGtBD64
http://www.youtube.com/watch?v=theKshCEGJw
http://www.youtube.com/watch?v=1_GQ9xIGMwo
http://www.youtube.com/watch?v=7-ExIOqSwP8
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
65er
« Reply #31 on: April 16, 2013, 01:53:57 PM »
Really good stuff Cody, consider me a fan!  ;D
-Wade
bluef100fe
« Reply #32 on: April 19, 2013, 06:32:02 PM »
I was playing around with the videos I posted the other day and took a couple still shots of my rear tire at the hit and also the truck just after the hit. Never knew the truck was wading up the tires so much. Probably killing the sidewalls long before the tread is worn off....
https://www.facebook.com/photo.php?fbid=10200323618107508&set=a.1694435875168.93601.1065954512&type=1&theater
https://www.facebook.com/#!/photo.php?fbid=10200323628587770&set=a.1694435875168.93601.1065954512&type=1&theater
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #33 on: April 19, 2013, 09:48:03 PM »
That is tire abuse, plain and simple LOL!  How much pressure are you running, Cody?  Have you tried increasing it any?  I'll bet you'd pick up some MPH if you added a couple PSI...
bluef100fe
« Reply #34 on: April 20, 2013, 09:36:54 PM »
Hoosier 2 9/10.5w-15 with tubes and 15 psi in them... any less and the truck wags its tail on the top end... I've tried more pressure with mixed results doesn't stay hooked on a marginal track with more than 15. I think the truck just needs bigger tires.. I might try stiffening the shock extension a little. I can also lengthen the ladder bars some but last time I tried that it didn't work out very well...
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #35 on: May 09, 2013, 07:40:42 AM »
So I made some changes to the 390... kinda felt like I was going backwards putting the old 427 medium riser intake back on this motor but it lined up with the valvecover rails the best on the C8AE-H heads that I installed this time around. So the 390 looks pretty stockish with ford part numbers on everything but the headers and the 4779-2 holley. Anyway the truck which has no grill, headlites, fenders, or hood went a new best of 1.61, 7.54@89, 12.007@109.2 mph this last weekend at WIR. Im very happy with this combo now. Just hope I can get that elusive 11.xxx out of it this season with all the sheetmetal on it. I have a video to post of the pass but I am having trouble getting it to upload.
New videos
http://youtu.be/sSwtNQaqzlI
http://youtu.be/UXPw8bdS51k
« Last Edit: May 09, 2013, 04:35:29 PM by bluef100fe »
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #36 on: May 09, 2013, 08:41:11 PM »
Congrats, Cody, 12 flat is moving right along with that truck, especially at WIR.  I still remember going sideways there... :o
bluef100fe
« Reply #37 on: May 10, 2013, 07:26:27 AM »
Thanks jay... and going sideways at a lot higher speed. I remember wartching you make that pass you had your hands full for sure....
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #38 on: September 23, 2013, 11:07:48 AM »
Little update on the little FE that could.... the truck engine got into the elevens a few times this past weekend.... story is on the other forum but the new best is 11.94 @ 109.5 with the whole front end installed... i want to get the truck scaled this week and see what it actually weighs after all the changes...  I went crusing in the f100 Saturday night and raced it Sunday morning... I can proudly say I have a street legal 11 sec. Truck with a iron headed pump gas 390 :)
Got to scale the truck and it is coming in at 3830 lbs. I didn't get to use race car scales but I believe these numbers are fairly accurate from the local feed mill. Eventually I will get it scaled properly then I will know all the percentages...
« Last Edit: September 26, 2013, 10:52:38 AM by bluef100fe »
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #39 on: January 17, 2014, 05:11:10 PM »
Just bumping this up for Wally... Side note...Hope to be going drag racing on the ice next weekend... If I get some video or pictures I will try to post them since I figure some members have never seen ice drags before... It pretty amazing how fast and quick some vehicles can go on 660 ft of smooth Ice.. Hope I can keep the rubber side down... I haven't done this in probably 8-10 years :)
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #40 on: January 17, 2014, 06:13:10 PM »
I'd check with other scales as well.
My truck at the metal scrapyard was 3920 and at the dump was 3890.
Mine is a 76 F100, 390/c6 long bed.  I do have an aluminum intake and radiator.
I guess it could be possible, but I haven't really tried to make mine weight less other than cutting off useless stuff.
« Reply #41 on: January 17, 2014, 08:32:11 PM »
I would LOVE to see some ice drag videos!  Do you run those spiky tires at the "track"?
bluef100fe
« Reply #42 on: January 18, 2014, 01:27:39 PM »
The tires consist of many hours of "screwing" with a drill or screw gun... Many pounds of drywall screws... Usually a case of beer or two and a tv with your favorite programs... Long and tedious task to make up a set of tires... There should be some pictures on www.merrillicedrags.com
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #43 on: February 17, 2014, 08:50:50 AM »
Finally had a weekend where I could go do some ice racing. Unfortunately this was the last race of the season and not at the location where I wanted to run but it still felt good to get in the seat and make a pass.  The starting line sucked as they weren't plowing/sweeping the lanes between runs like they do at the merrill ice drags. Truck had to dig through 2-3 inches of loose snow/ice before getting down to the good solid ice.  So the times are slower than what I was hoping for. Video links to you tube video....
https://www.youtube.com/watch?v=9YgNuvxaBiw&noredirect=1
https://www.youtube.com/watch?v=bdnNbJya4-g&noredirect=1
In the second video I'm racing against an S10 with aluminum headed sbc and two stages of nitrous which I don't know if he sprayed both kits or one or none. He said he was just gonna spray the one small kit.  All I do know is he only made the one run and he couldn't get his truck restarted when it died in the shutdown area.  I talked to the owner/driver before we raced and he claims his truck runs 10.40's on the asphault in the 1/4 mile.  I was expecting to get my @$$ handed to me but as you can tell from the video that wasn't the case he did beat me but only by a tenth. I was happy to take 2nd since I was the only ford in the class and I had the heaviest vehicle by a large margin. Only 2 tenths of a second seperated the top three of us.  I'm probably the only one running stock heads and intake also lol.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
jungle0758
« Reply #44 on: February 17, 2014, 09:44:23 AM »
 Cool truck!!! it reminds me of P.S.E.s truck.I have a soft spot for mid 70s F series trucks,i have a 74 F250 4x4 with a stroked 427 tunnel port on methanol.Bought mine in 1976 still thumping after all these years.Keep it up CODY!!!
« Reply #45 on: February 17, 2014, 09:52:43 AM »
That's just plain cool Cody.
bluef100fe
« Reply #46 on: February 17, 2014, 04:21:32 PM »
Thanks guys glad you liked the videos... Hopefully I will get to do more events next winter
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #47 on: February 17, 2014, 05:09:17 PM »
http://www.youtube.com/watch?v=b6hoLDHxoy0
landspeed racing on ice in Sweden
« Last Edit: February 17, 2014, 05:17:21 PM by Heo »
« Reply #48 on: February 17, 2014, 05:20:00 PM »
How is this for insane :o :ohttp://www.youtube.com/watch?v=ChRauhJk8Q8
125 mph on a riding mower on ice
« Last Edit: February 17, 2014, 05:25:50 PM by Heo »
rockittsled
  • 1976 F-250 390 4v C6
« Reply #49 on: February 19, 2014, 04:19:39 AM »
I wonder what power you are making at THAT temp   ;D
bluef100fe
« Reply #50 on: February 19, 2014, 09:26:31 AM »
Hard to tell since I don't have a trap mph and with slippage at the start the E.T. Would also skew the results of any calculator. The 390 should be somewhere between 450-500hp according to werbyford.. The air density was around 100 that day which is pretty high but I don't know what the humidity was.. Anyway I'm guessing it's somewhere around there.. Still not enough :)
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
jungle0758
« Reply #51 on: February 19, 2014, 09:48:40 AM »
I am trying to find a video of my 3/4 ton 4x4 beating a 454/4spd 71 chevelle ss multiple times at ENNIS back in 1985.if I find it I will get it out on youtube.
bluef100fe
« Reply #52 on: January 17, 2015, 01:50:06 AM »
Trying to upload a in cab go pro vid from this summer... Good old 390 doing it's thing :)
http://youtu.be/s2OhV3ou4Gg
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
NIsaacs
« Reply #53 on: January 17, 2015, 07:08:48 AM »
Cool videos and thread, thanks for the bump, I didn't see it before. That ice racing looks scary..... do you still have your heater hooked up? lol
Now for some sled puller videos!
Nick
2021 Ram 2500 4x4 Cummins of course!
2017 Ford Escape, 2.0 Eco Boost
2001 Ram 2500 4x4 QC short bed, Cummins, 6spd, some mods
1991 Dodge D250, reg cab, Cummins, 5spd, mods
1974 F-350, Cummins, 5spd, 3spd aux, mods
1975 F-250 4x4, 428, C-6, Sled Puller
bluef100fe
« Reply #54 on: January 17, 2015, 07:31:51 AM »
Nick here's a pull video from a couple years ago... All iron FE power.... Enjoy
http://youtu.be/wFKnsCv0aFo
http://youtu.be/w6l6jREfvnQ
« Last Edit: January 17, 2015, 07:56:59 AM by bluef100fe »
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
NIsaacs
« Reply #55 on: January 17, 2015, 07:49:04 AM »
Nice! Good running Ford, but how did you come up with a F350 4x4 in 1974? I found your other video too :)
Nick
bluef100fe
« Reply #56 on: January 17, 2015, 08:03:06 AM »
Dunno much about the trucks origins except that it's been pieced together many times from very many donor parts trucks over the years...Cab has F350 custom badges on the side and it's got a 1974 grill... That's how we came up with 1974.... It's referred to as the purple truck or the stock truck normally... :)
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
NIsaacs
« Reply #57 on: January 17, 2015, 08:11:19 AM »
Home grown is good! My 3 fords are color coded too, the maroon one, the brown one and the green one, my son has the maroon one now.
Nick
« Reply #58 on: January 17, 2015, 09:51:11 AM »
Nick
Well you'd have LOVED the truck I had when I was a kid..... it was Maroon, Brown, AND green.
bluef100fe
« Reply #59 on: January 17, 2015, 10:52:21 PM »
Ice races from today... Got to play around with my go pro finally
http://youtu.be/zyWTJDIbyMQ
http://youtu.be/3Hv9HGB5JuU
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
NIsaacs
« Reply #60 on: January 18, 2015, 06:14:59 AM »
I am amazed at how well you hook up on that ice, looks cold and scary to me! The first video won't work, says private? What is a go pro? What rpm are you shifting at? It sounds great!
Nick
bluef100fe
« Reply #61 on: January 18, 2015, 06:42:49 AM »
I accidentally had video set to private... It should play now... I shift about 6300-6500 rpm depending how the track is... I have a go pro hero 3 video camera that I can mount anyware on the truck... Thanks
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
NIsaacs
« Reply #62 on: January 18, 2015, 09:33:03 AM »
Okay video camera, that's why the video/audio is so good. I am thinking the JR. West Coast Mirrors are slowing you down at speeds of 109! lol
Nick
fairlanegt427
  • 64 falcon 482 pond motor/ 65 comet 428
« Reply #63 on: March 15, 2015, 05:46:30 PM »
i watched your first video at the track racing a snowmobile,  i hate that,  we all have 4 wheel cars or trucks can we just race 4 wheel cars or trucks please jmho.  also i see your are nipping away at your e.t. getting a tenth here and their, here is my question,  have you ever tried taking the california mirrors off each side to see if that helps you any with the e.t.   it maybe nothing at all but remember wind resistance starts about 35 to 40 mph.  i guess its just for my own dumb curiosity.  i am a truck driver and if youve ever noticed these newer semis have some aerodynamic mirrors on them.  so for what its worth it think taking them off to race should help you.
bluef100fe
« Reply #64 on: April 14, 2015, 05:20:15 PM »
I took the mirrors off once... I didn't really notice much difference... Less than a tenth IRRC... Back when the truck was 4300 lbs and running 13's :)
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #65 on: April 14, 2015, 07:46:12 PM »
Those aren't mirrors, they're bug deflectors....to deflect bugs into the interior and right into your face and chest. I know from experience. ;D
cobracammer
« Reply #66 on: April 23, 2015, 12:59:49 PM »
Got stung a few times by (almost dead) bee's when they bounced off U-Haul mirrors just like those!!!  LOL  Good times
Jason
bluef100fe
Re: 390 pump gas deal... 1976 F100 aka "The Mistress"
« Reply #67 on: April 25, 2017, 10:00:43 AM »
New video from TNT last weekend, truck leaves violently with the little rented mule engine.... https://www.facebook.com/tomeighty/videos/502098733247712/
https://www.facebook.com/ladowski/videos/10210750240646555/
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #68 on: June 14, 2017, 06:14:31 AM »
A link to my office view from the annual all ford memorial race in hardinsburg KY at US 60 dragway. Where the mistress ran a new best ET of 7.29 @ 91.73 mph with a 1.535 60 ft.
https://www.facebook.com/ladowski/posts/10211159388915006
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #69 on: June 14, 2017, 06:38:02 AM »
A better launch this time compared to the April vid, for sure.  ;)
Still, some side-stepping Corey after watching it a few times. Perhaps get some close-up vid footage behind the truck, shooting right off the pavement to catch the tires, suspension movement, etc.
bluef100fe
« Reply #70 on: June 16, 2017, 05:49:41 AM »
For a old truck leaf spring system I think thats about as good as it's gonna get.  Time will tell as I'm taking the truck all apart to fix a few things, rearend, cab, rollbar, engine, transmission, suspension, pretty much everything... hope to have it back out for drag week...
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #71 on: October 04, 2017, 12:21:51 PM »
Well I missed drag week by a couple weeks, but I finally got the mistress back to the track. Link to some videos posted on Facebook my wife took.
https://www.facebook.com/ladowski/posts/10212109799714682
 I was making changes after each pass, truck kept getting faster until the last pass when I tried the short and fat drag radials I bought to try and crutch the streetable 4.10 gear in the truck, it really probably needs a 4.57 gear.. Will have to try them again on a good track someday. Truck gained 150 lbs between the new rearend, disc brakes, 35 spline axles, 6 point rollbar, aftermarket block, and other safety items. After I redo the wheel tubes and bed floor I'd guess it's gonna gain at least another 50 lbs and change out the aluminum center section for a iron one. Still running on just the edelbrock mechanical fuel pump and 3/8 line, will have to finish the install of the 1/2 line and electric pump and see if the performance improves any.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
