Author Topic: weight of a 428 f e  (Read 12851 times)
bn69stang
weight of a 428 f e
« on: September 14, 2014, 07:13:03 PM »
what would  the engine way ? ,  428 c j  with aluminum heads , aluminum intake , aluminum water pump , f p a headers and a lakewood scatter shield  ? .. Bud
Re: weight of a 428 f e
« Reply #1 on: September 14, 2014, 07:28:19 PM »
My 390 stroker weighed 490 pounds with aluminum heads and intake, water pump, FPA headers, and alternator.  No starter or scattershield.  Hope that helps - Jay
bn69stang
« Reply #2 on: September 14, 2014, 07:47:14 PM »
Thanks Jay it does , i am thinking about a coil over shock conversion and maybe trimming the shock tower s a bit , for room and the info helps choosing spring rates . To me thats small block weight area .. Bud
sumfoo1
« Reply #3 on: September 15, 2014, 08:40:54 AM »
Yeah i think a stock fully dressed 352 is a hair over 700lbs  so there is a lot of savings to be had there.
Ratbird
« Reply #4 on: September 15, 2014, 11:42:23 AM »
I just installed my Edel RPM Performer heads yesterday. With springs and valves they weighed 27 pounds. The old c4ae's with springs and valves weighed 47. That's 20 pounds a side.
I think the original intake weighed 85-90 pounds. The RPM performer was like 23ish??
Total saving of about 110 pounds.
Anyway.
pure fun
bn69stang
« Reply #5 on: September 15, 2014, 07:38:15 PM »
Thanks Dave appreciate it .. Bud
TimeWarpF100
« Reply #6 on: September 15, 2014, 10:19:22 PM »
FE is not that heavy. Closer to 620lbs.  You are closer to weight of a 385 series engine.
sumfoo1
« Reply #7 on: September 16, 2014, 06:56:19 AM »
maybe cause mine had a/c lol.
lalessi
« Reply #8 on: September 16, 2014, 08:28:35 AM »
FYI, check this out, Ford engine weight detail....
                       http:/raceabilene.com/kelly/hotrod/FordWeightDetail.html
Lynn
Lynn
« Reply #9 on: September 16, 2014, 09:53:22 AM »
Lynn
Try it now:
http://raceabilene.com/kelly/hotrod/FordWeightDetail.html
« Last Edit: September 16, 2014, 09:54:56 AM by machoneman »
bn69stang
« Reply #10 on: September 16, 2014, 06:20:41 PM »
Thanks for the web site , just what i was thinking small block range and a bit lighter .. thanks guy s   Bud
sanddoc
« Reply #11 on: November 28, 2014, 04:32:10 PM »
http://www.hotrodreference.com/893/common-american-v8-engines-weight-comparison-chart/
I often hear how heavy the Ford engines are, so do some comparison.
  Seems like the chevy is about 40lb heavier then the comp Ford
