Author Topic: Jay or Barry or Others. Need help choosing proper header size for a 482  (Read 20837 times)
TimeWarpF100
Re: Jay or Barry or Others. Need help choosing proper header size for a 482
« Reply #30 on: August 19, 2014, 09:50:44 AM »
you don't put the plug in for the heads?
I would assume you are talking about when I cc'd the head?
Look close there is a 3923 or 24 in there . .
« Last Edit: August 19, 2014, 02:34:28 PM by TimeWarpF100 »
« Reply #31 on: August 19, 2014, 10:31:36 AM »
No way a stockish 427 like the one you described puts down 420 HP at the wheels.  Either that cam was far from stock, or that was one optimistic chassis dyno.  Your 482 will blow away that 427 if its set up correctly...
TimeWarpF100
« Reply #32 on: August 19, 2014, 02:39:00 PM »
I will try to find the cam card. I do know the 427 Comet was faster than my friends Viper GTS . .
Could have been a happy dyno, a 64 Galaxie single 4v made 400 at the wheels. It was on a stuska dyno first and made 505.
Hopefully will soon find out. The 1 7/8" Misc Mandrel Bends from Schoenfeld showed up today.
TimeWarpF100
« Reply #33 on: August 21, 2014, 11:06:05 PM »
Found the cam card after quite a bit of looking.   Looks pretty STOCK to me. HAHAHA
This was actually cam 2. Way back in 2002 so the memory slipped along with the racing bench I was sitting on!
One is card I got with cam the other is current. Slightly different specs
Incredible performance with the combo I had at the time.
A Sleeper it was!
« Last Edit: August 21, 2014, 11:28:38 PM by TimeWarpF100 »
bluef100fe
« Reply #34 on: August 22, 2014, 10:03:48 AM »
That's comp cams small drag race grind... Works good in a warmed over 390 also... :)
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
