Author Topic: 482 tunnelport pick up  (Read 13750 times)
Re: 482 tunnelport pick up
« Reply #15 on: August 13, 2014, 05:36:04 PM »
Yes, there's some confusion going on about the carbs. We will try to help you through it. There will be a "LIST" number on the airhorn of the carb. If you could post that it would help. As far as the metering plate goes I will say there are a couple options you can do. The easiest one, Quick fuel makes a replacement metering plate that takes Holley jets, but will fit under the Holley float bowl. Available at Summet, Jegs, etc. Another option, the metering plates have an I.D. # you can use to find the specs you currently have, then you can try to find new or used plates with smaller main jet holes.
« Last Edit: August 13, 2014, 05:38:55 PM by thatdarncat »
bigswede442
« Reply #16 on: August 13, 2014, 11:32:03 PM »
The beast is alive! we fixed a nasty header leak and to had tighten the frost plugs some more. But its making noise again. I got a guy coming tomorrow to tune the carbs . hopefully by this time tomorrow it will be back in its home.
