Author Topic: FE Oil Filter with Reduced Outside Diameter?  (Read 14116 times)
Ratbird
Re: FE Oil Filter with Reduced Outside Diameter?
« Reply #15 on: July 17, 2014, 12:09:07 PM »
Seems to me a filter that does a better job would also get clogged sooner and need replaced more often. (Speaking solely about the filtering aspect of the filter)
pure fun
Qikbbstang
"better filter clogged sooner" au contraire the better filters use
« Reply #16 on: July 17, 2014, 09:50:07 PM »
wire cloth backed microglass fibers. These fibers are much smaller then the cellulose or plasitmeric  fibers in cheaper medias. The result is there is a lot more holes or void space in the media so they flow well, have low resistance, can hold a lot more debris and do a far superior job on capturing/holding particles.   Think of the microglass fibers as needles vs polly- fibers as toothpicks vs cellulose fibers as pencils in size.
« Last Edit: July 18, 2014, 12:34:23 PM by Qikbbstang »
fe66comet
« Reply #17 on: July 17, 2014, 10:12:14 PM »
I have a filter mount that faces forward, it came out of a F250 4/4. That would work if you have room?
