Author Topic: port injection cam?  (Read 4384 times)
fe66comet
port injection cam?
« on: June 23, 2014, 08:17:41 PM »
I am gearing up for when I get my intake adaptor to run my Ford injection intake. I currently have a carbureted cam in the engine and I am having comp cams grind up a new one. I am thinking of something like this, spec. wise, what do you guys think? I am going with a roller cam so rpm is in the 2000- 6500 range. COMP Cams 35-775-8 thanks guys Jon
Re: port injection cam?
« Reply #1 on: June 23, 2014, 08:49:00 PM »
What is your current cam and can you adjust injector timing?
I run more cam than that and less lobe sep and it idles nice, no bad behavior.  That's not a bad cam for a cruiser, but it'll be pretty mellow
fe66comet
« Reply #2 on: June 23, 2014, 09:02:08 PM »
One I have now is 594/598,287/293 112 separation. I haven't ran it yet so I have no base line but the separation seems to be the difference mostly. The cam I need is for a 445 with moderate ports, stage 3 port and combustion work from Barry. I am going with a Box R trick flow intake that has about 300 cfm untouched per runner. I could go with a little more lift say .625/ 625 but I do not want to push piston clearances too much.
« Reply #3 on: June 23, 2014, 09:07:09 PM »
That cam you have is fine for EFI, 112 is already spread, especially at that duration.  EFI can generally handle quite a bit more overlap than that
For example, mine is 286/292 110, for 69 degrees overlap
Your current cam is 66 degrees overlap.
I sure wouldn't spend any money, that cam will run strong, overlap is king for mid range WOT power and as long as you don't go too tight and give the O2 sensor odd data, it'll love the tighter spread
fe66comet
« Reply #4 on: June 23, 2014, 09:26:37 PM »
Cool I'll give it a try, I have to still send the heads off for the final port work and chamber shaping. But at least I can button up the bottom end Thanks .....Jon
