Author Topic: C-6 upgrades  (Read 15716 times)
Grbmaverickmo
C-6 upgrades
« on: February 15, 2014, 02:36:34 PM »
Ok MY C-6 is fresh and works fine but I`m putting the higher stall in now so what would be some good upgrades while I have it out? Thinking deep aluminum pan is a def. How bout a shift kit or transpak? I have run a diff servo in my c-4`s by PA auto is there somthing available for the c-6s? As allways Thanks for any help
mammyjammer
Re: C-6 upgrades
« Reply #1 on: February 15, 2014, 04:40:56 PM »
http://www.broaderperformance.com/33-ford-c6-
I'm not a C-6 expert but I worked with Broader when I put mine together and he was very helpful and fairly prics.Broader's
Stage 5 shift kit shifts very firm. Shift kit is $75.00 and a modified valve body with a shift kit is $150. I would recommend spending the extra $75 bucks for the whole valve body.
Re: C-6 upgrades
« Reply #2 on: February 15, 2014, 05:17:20 PM »
If it was me?
shift kit as mentioned, also #9 roller and reverse hub with longer splines, make sure I had at least 5 frictions jammed in the drums.
For what it's worth... I have the broader shift kit (transgo SK6) in my truck.  It's a daily driver pickup truck and the stage two shifts perfectly for my usage, wouldn't have wanted to go much harder on shifts.  For a more aggressive car I could see 3-5
babybolt
Re: C-6 upgrades
« Reply #3 on: February 15, 2014, 07:18:28 PM »
There's a lot of info on C6's in the 429-460.com  and 460ford.com forums.  Most of the info is in the sticky's or older listings.
drdano
Re: C-6 upgrades
« Reply #4 on: February 15, 2014, 10:24:31 PM »
I put an E40D wide ratio kit in my last C6 and really liked the -10% first gear and -5% second.
aarons428
65 f-100 swb
428 4v
c-6 trans wide ratio
3000 stall converter
torino front stub
latter bar style rear suspension w/air bags
11.96@110mph
Faron
Re: C-6 upgrades A Temp Guage
« Reply #6 on: February 15, 2014, 11:09:23 PM »
A trans Temp Gauge that goes in the outlet cooler line,( its in the front ) autometer makes a manifold or just use a 1/2 pipe Tee and some fittings,  I think its  a MUST do  C-6 and C-4's run Hot , add a Higher stall Conv and it gets worse , do NOT put the Gauge in the pan it will give you Average not Peak temps , keep the fluid under 200 ( if its reg Type F) and under 250 if its Synthetic ( I like Amsoil Super shift ) AND of course to keep it cool enough you may need a bigger cooler , or another one , don't just assume if you have a Big cooler its all you need , the other posts above offer the other suggestion , I build C-6's and C-4's ( yep I do more than Recurve Distributors  8)
Re: C-6 upgrades
« Reply #7 on: February 16, 2014, 09:38:42 AM »
temp gauge is nice.  also while you are cutting into the cooler lines I install one of these too:
http://www.summitracing.com/parts/bmm-80277/overview/
not to mention I always put a drain plug in a pan, just cuz.
Grbmaverickmo
Re: C-6 upgrades
« Reply #8 on: February 16, 2014, 01:58:56 PM »
Cool Thanks. That website for valve bodies and the r-servo is exactly what I was asking about
Re: C-6 upgrades
« Reply #9 on: February 16, 2014, 02:19:39 PM »
Then you can get into the levers.
Which lever is in your trans?
Grbmaverickmo
Re: C-6 upgrades
« Reply #10 on: February 16, 2014, 06:45:43 PM »
Not exactly sure but its not the performance one cause it doesn`t have the r-servo.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
Re: C-6 upgrades
« Reply #11 on: February 16, 2014, 08:06:43 PM »
I have dealt with Jay @ broader performance for my C6 behind a 6.9 turbo Diesel. I rollerized my C6 with a gear reduction kit , with the 6 gear planetary. And a stage 1 shift kit from Trans Go. All the parts fit real nice and didnt have to cut down the case to do it. I too run Amsoil in my stuff. They make some of the best tranny fluid out there. Not only am I a client, I'm a dealer for them LOL.....
« Last Edit: February 16, 2014, 08:14:51 PM by Ford428CJ »
Wes Adams FORD428CJ
64 Falcon 428FE
Re: C-6 upgrades
« Reply #12 on: February 17, 2014, 01:33:21 AM »
Next question.
Which servo do you have now?
Using a R servo and an F lever can crack the case. It puts too much clamping force on the band.
The CJ C6 came with a R servo and B lever.
If you have a P servo and use a F lever that is a good mix.
Or if you have an H servo and a E or possibly a D lever that would be a good mix.
The levers are different lengths and the servos are different diameters. Too much and you can crack the case.
Bottom line is you don't need an R servo, you need the right lever for the servo you have. jmho
Grbmaverickmo
Re: C-6 upgrades
« Reply #13 on: February 17, 2014, 08:36:40 AM »
Oh wow. Ok I will def have to look a little deeper at it when I have the valve body out and see what combo I have. Thanks thats exactly the kinda of stuff I need to know.
manofmerc
Re: C-6 upgrades
« Reply #14 on: February 20, 2014, 06:55:39 AM »
If you are wanting to use an r servo be aware that it wont fit an early case .Early being 66-68 and possibly some 69 cases .And even so the sonnax r servo sometimes has problems .The best c6 info is located on the two 460 forums as others have stated .On one I did a buildup of a c6 for my 460 based dragcar .On of my problems was the sonnax servo .If you really want an r servo stay away from the sonnax .TCI has one and I believe another company Superior trans ? have their own now used to everyone used a repackaged sonnax .The sonnax can be made to work .You have the larger diameter piston turned down so it will slide easily in the bore .The o rings that are on the piston stem dont last either .On the 460 forum they have a sticky with lots of c6 info .On the 429-460 forum lots of good info too.Another shout out for broader performance .The direct clutch drum he sells (high gear) comes setup for five clutchs and has a series of hole drilled in it .I have installed two of these .Nice snappy 2-3 shift .By the way my two c6s with stock servos shift as good as the one with a modified sonnax .Good luck to you with your build .Doug
