Author Topic: Plugs are fouling  (Read 21753 times)
Ford428CJ
  • FE FREAK!
    • Hillside Auto
Re: Plugs are fouling
« Reply #30 on: February 01, 2014, 10:47:29 AM »
Plug looks good. It might be a little on the hot side. You can tell by the grounding strap color. The perfect or ideal color change should be at the radius of the strap.  When the plug is to hot. It is closer to the threads. And opposite when its too cold of a plug. It will be closer to the tip of the grounding strap.
Also a good way to tell if you have the right heat rang plugs for your ride! JMHO
Wes Adams FORD428CJ
64 Falcon 428FE
Ratbird
« Reply #31 on: February 02, 2014, 02:12:21 PM »
Thx for the feed back Wes. I'm going to play with the timing some more today, before the football starts.
Dave J
pure fun
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #32 on: February 05, 2014, 10:44:08 AM »
Your very Welcome Dave! Glad I could help out  ;)
Wes Adams FORD428CJ
64 Falcon 428FE
