FE Technical Forum
roller cams
Pages:
All
Topic: roller cams (Read 14035 times)
0 Members and 2 Guests are viewing this topic.
Re: roller cams
Reply #15 on:
January 12, 2014, 06:56:06 AM »
If you plan to approach the 600-625 lb open pressure ballpark, then yes, I would look hard at timeserts or another rocker setup. I run about 170/400 on hyd rollers and have never had a problem there.
YouTube: Lykins Motorsports
bn69stang
Re: roller cams
Reply #16 on:
January 12, 2014, 07:36:44 AM »
Ok thanks Brent , most likely it will be a hyd roller , on the stroker 28.. Bud
69 mach 1 , 428 C J Blue Oval Performance BBM heads -T@D rocker s- Blue thunder intake - Comp hydr roller - MSD ignition - FPA headers- Holley 850 hp double pumper - TKO 600 - 9 inch 3.89 Detroit Locker . ride tech coil over conversion - power rack @ pinoin steering - 13 inch drilled @ slotted 4 wheel disc brakes ..
bn69stang
Re: roller cams
Reply #17 on:
January 17, 2014, 07:56:28 PM »
Brent give me some specs on hyd roller s you have used on 427 , 428 , or 445 s , was thinking something in the 234-240 @ 50 and maybe in the 570 s on the lift , on a 110 - 112 lobe for the current 434 i have .. Bud
Pages:
All
FE Technical Forum
roller cams
