Author Topic: Some pictures and info of the Sideoiler Garage block....  (Read 16584 times)
chris401
Oil Feed
« Reply #15 on: December 17, 2013, 12:19:14 AM »
Thanks for pictures.That makes some sense. I started working with aluminum split case piston type aircraft couple years ago. The new ECI cases are the same way, #1 main oil galley off like #1 FE. It feeds directly off main galley and cam is below crank. I cant see what keeps them from making a straight shot.
