FE Power Forums > FE Technical Forum
How do you size your TQ converter on your heavy car?
Bad Byrd:
I dont have a ton of experience sizing TQ converters on these heavier cars.............not a lot of experience with these heavier old school cars. Generally as a whole I dyno the motor check the TQ curve and size the gear ratio and TQ converter based off that information.
I am not going to go to that expense on this car, the car isnt built to this level so its a bit of a guessing game for me. Based off of Mr Brown guess of me having 475HP and a 3900 lb car with 3.50--1 gear ratio what would you run? Right now I am thinking a 2200 Stall converter.
Motor is a 445 Ci Stroker
4.160 Bore
4.125 Stroke
Roller Cam
The cam was custom ground based off of 3.50-1 and a 2400 stall. However knowing this thing is HEAVY, I am concerned of overheating the trans fluid, even though I have a redundant trans fluid cooling system...............Radiator and independent trans cooler with fan.
jayb:
I always used to worry about overheating the trans fluid with a loose converter too. Over the last 10 years I've gradually stepped up stall speeds on various cars while monitoring transmission fluid temperature, and have been really surprised to find that until you are running the car down the drag strip, the fluid doesn't seem to overheat at all with a very loose converter. Currently I'm running a 5600 stall converter in my Mach 1, which is 3600 pounds with me in it. The transmission fluid temperature never goes over 190 degrees, even on a hot day while driving down the freeway. I have an Earl's transmission fluid cooler on the car, but its not a big one, probably 4" X 10" or so. Temperature reading is taken from the pan.
At the track at the end of a run I'll see the temperature rise 30 degrees or so without use of the transbrake. It will get VERY hot if you apply the trans brake and hold the car on the brake for any more than a second or so at the starting line, so I try to avoid using the transbrake.
Most of this may not be relevant to your situation, but the point is that you shouldn't worry about the converter selection affecting your transmission fluid temperature. I'd heard that for years from various sources, but based on my experience it has turned out to be an old wives tale. The converter selection for your vehicle will be more about how much "slushiness" you can deal with just driving the car around. 2200 RPM is pretty close to stock for stall speed; I think I'd go at least 3000 with your combination, and probably even 3500.
afret:
I think Jay is right. You always hear about keeping the stall below highway cruise RPM or the trans will overheat. I've always run loose converters and never had a problem with the trans fluid getting hot. I had a 4500 converter when I used to drive to the track with a medium size B+M cooler and the temp wouldn't go much above 170* on the highway in the desert summer heat. I only had 3.91 gears with a 28" tall tire going about 55 down the road so the revs weren't high. The car is a '69 Mustang and isn't very light.
Have gone to a loose 8" converter now with the same cooler. Haven't driven it much but the trans temp has been fine going down the road.
Going loose (up to a point) will help your car launch if you take it to the track and let the car idle better in gear if you have a bigger cam. Jay's recommendations sounds good to me.
Bad Byrd:
Not to be argumentative Mr Brown but when I went to a 3200 stall on the wifes 32 roadster I saw an increase of well over 30 degree's trans temp on the freeway. So I added a fan to the trans cooler and I got 20 back! Now that is a 383 Stroker SBC with a TH400, but that car doesnt weigh 2200 lbs.
So I just assumed that with a big ole Tuna Boat I would see even a greater increase in heat.............maybe the C6 is a better trans then the TH400 in this scenario but I wouldnt think so!
e philpott:
camshafts and converter's go together along with intended application , all other factors are minor ..... converter's job is to get the engine into it's operable rpm torque range and cam plus cubes is the main determining factor ....... I totally agree with Jay , I ran a 5000 stall converter on street for thirteen years with no problems or over heating in a C6 ..... best way to size a converter is to call the converter manufactorer and give him your application (street , street and strip or strip) engine size , cam , gear and weight .... one thing to consider is converter diameter , a small 9 inch converter has way less fluid capacity than a 11 inch converter , my 5000 stall converter was made with a 9 inch cover to help retain some fluid capacity .... even with a deep pan it only holds around 7 quarts total capacity , so based on total fluid capacity the 7 quarts has to run a little hotter than a 12 quart system just from lack of fluid capacity
Navigation
[0] Message Index
[#] Next page
Go to full version
