Author Topic: 390 FE for Cobra  (Read 367 times)
Boiler Ben
390 FE for Cobra
« on: November 12, 2026, 03:57:04 PM »
Just got back from dyno testing my 390.  This is a for a Factory Five Cobra I am building.  It's a fairly mild build with lower compression ratio for running on 87 octane.  More details about the configuration here:
https://fepower.net/simplemachinesforum/index.php?topic=13332.msg141393#msg141393
Final numbers are 365 hp @ 5700 rpm and 401 ft-lb @ 3900 rpm.  I'm sure I could have squeezed more out but I don't think I'll need it for this tiny car.  The torque curve is pretty flat (388 ft-lb @ 3000) which should make it fun to drive.  Just happy it didn't blow up or leak anything.  The shop also tried race fuel and got 395 hp.  Very happy with how it all went.
mygasser
Re: 390 FE for Cobra
« Reply #1 on: November 12, 2026, 05:02:08 PM »
souns like it'll be a lot of fun in that cobra rep'  ;D
neil.
« Reply #2 on: November 12, 2026, 06:40:14 PM »
Where did you dyno?  Sounds like they have a very conservative dyno or they gave you uncorrected numbers.  I’d expect around 425 hp with that combo.  Edel heads, right?
63ragtop
« Reply #3 on: November 12, 2026, 09:21:01 PM »
Picked up 30 HP from adding race gas in motor with presumably under 10 to 1 compression????
Boiler Ben
« Reply #4 on: November 13, 2026, 09:20:12 AM »
This was at Wegner Automotive in Wisconsin.  They were great to work with and I would definitely recommend them.  The printout says corrected torque and power.  Not sure if it is a conservative dyno but after mine, they were getting ready to test a supercharged Coyote that was expected to be over 1000 hp.  Wish I could have stayed to see it.  And yes, Edelbrock heads.  Port alignment wasn't perfect.  Not sure how much that contributed.  No regrets though.
MRadke
« Reply #5 on: November 13, 2026, 02:07:33 PM »
Wegner automotive is about 30 miles from me.  If I remember right, they built engines for Bobby Allison back in the day.
