Author Topic: How many header bolts are you using on shock tower cars  (Read 1733 times)
« on: September 10, 2026, 03:51:33 PM »
You guys with headers in shock tower cars, are you using all four mounting bolts or just side two bolt locations and/or along with top bolt ?
That bottom bolt in my 63 Fairlane is a real mother F#*cker :)
fastback 427
Re: How many header bolts are you using on shock tower cars
« Reply #1 on: September 10, 2026, 05:15:35 PM »
I use as many as I can get to. The small headed header bolts help a lot, along with some cheap wrenches I bent.
As long as they are on opposite sides you should be ok...
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
mike7570
« Reply #2 on: September 10, 2026, 08:05:29 PM »
I put in 28 on the large tube Hooker race headers in a mustang. But then I’m a bit OCD.
New REF race headers only have 8 per side (top and bottom) easier than the Hookers but like the Hookers you have to install the individual tubes in the right order or your removing them multiple times until you get it right.
Ask me how I know. Haha!
« Last Edit: September 10, 2026, 08:13:39 PM by mike7570 »
mike7570
Tools
« Reply #3 on: September 10, 2026, 08:11:58 PM »
These are a must have for the top and bottom bolts, I wish I had picked them up sooner.
« Last Edit: September 10, 2026, 08:59:09 PM by mike7570 »
GerryP
« Reply #4 on: September 11, 2026, 07:07:23 AM »
Nearly every engine on Earth uses two bolts per port.  Some, like the GMs, Mopars, and AMCs with siamesed center ports, use two for those ports.  Two works just fine.
« Reply #5 on: September 11, 2026, 10:45:33 AM »
Thanks Gerry, Ive fought the 4 bolt for 30 years and think I'll take an easier route this time, Mike I hear you on the 4 bolt and OCD as I've been doing it that way since the beginning , Fastback 427 I been using the small bolt headed bolts too but my Crites headers are still tight
gregb
« Reply #6 on: September 11, 2026, 11:06:21 AM »
I’ve on,y ever used two per port…..
Mark Bliss
« Reply #7 on: September 12, 2026, 02:47:39 PM »
I guess I am a glutton for punishment.
I have installed/removed headers on my Mustang multiple times over the years. 3 different brands (I dont remember the names except the current Hooker Super Comps)
First was removal of the TRI-Y style that was on it when I bought it in the mid-70's. I then installed a set when I rebuilt the engine since it had been sitting in an impound lot for 9 years with the hood off and intake stolen.
I had transmission problems and had that thing together and apart too many times...
Got frustrated and decided the fix was to convert the C6 to a top loader. Well dont you know those headers were auto only. So along came the Hookers. Had those on and off a few times. Last time to address gasket issues.
I found the sharp edges of the weld bead at the tubes readily cut the gaskets and caused premature leaks. I "engineered" a fix and they stayed on for a long time.
I think I put in all the bolts in every time. GT heads.
I did the "custom bent" trick, and also ground the box end of my special wrench to thin it out a bit. The special sauce was before installation I located the tight spots where the wrench really wouldnt fit and very lightly dimpled the tube around the bolt area so the modified box end would fit on and off the bolt for final stage tightening. This helped a lot, but it's still a pain... (see my previous post on avoiding doing it in the car)
Edit- I just remembered the second set were from an obsolete brand Casler or similar. They were a sub-brand of a better known manufacturer.
« Last Edit: September 12, 2026, 02:55:11 PM by Mark Bliss »
1of1044
« Reply #8 on: September 13, 2026, 03:07:06 PM »
I’m using all 4 bolts per primary tube on a 68.5 428 Mustang using Doug’s headers D427 with TFS heads. Used special wrenches (5) that I made up to get in tight places. VERY tight. Several guys have said they only use 2 with no issues but I managed to get all 4 in.
sixty9cobra
« Reply #9 on: September 13, 2026, 07:23:53 PM »
4 bolts per port Hooker Headers in a mustang.
« Reply #10 on: September 14, 2026, 03:45:15 PM »
which ones are the D427 ?  I've been looking at some Doug's D627 big tube headers for a 1965 Fastback with BB shock towers project. My 1963 Fairlane FE with Crites 2 inch headers are tough to get to the bottom bolts
1of1044
« Reply #11 on: September 14, 2026, 05:38:44 PM »
My bad. Should be D627.
« Reply #12 on: September 14, 2026, 08:44:02 PM »
Are you installing the headers on engine first and then installing it in the engine bay ? Or putting them on after the engine is installed?
« Reply #13 on: September 15, 2026, 07:44:09 AM »
Two is all you need, tightened evenly and with care.
However, when mine was sitting on the stand waiting to go in, I put all that I could.  On my 6114s, it wasn't all, but it was most.  It's been literally 20 years since it went in, so I'd have to look to see which
1of1044
« Reply #14 on: September 15, 2026, 02:47:53 PM »
e philpot—-engine in.
