Author Topic: (Potentially) Dumb question for the experienced Mustang guys...  (Read 2360 times)
Re: (Potentially) Dumb question for the experienced Mustang guys...
« Reply #15 on: October 04, 2026, 08:31:14 PM »
I agree a Monte Carlo bar is needed, but top bolt interference is typical with cylinder #5, especially with the extra bracing on a CJ car. Ford never used the top/bottom bolts on those cars for that reason.
On mine, I was aware of this issue when I was restoring the body, so I took a rosebud torch and a 4x4 chunk of wood, heated it cherry red where that bolt is and beat it back against the shock tower. Usually there's about a 1/4" gap or more there where you can gain a little room. I managed to get all 16 bolts in, but that #5 top bolt still pecked at the brace, and yes, it's annoying. I fixed the problem by making a turnbuckle strap to go from the head to the sway bar mount. It's a perfect lineup, easy to make, and it stopped the pecking. It also helps the motor mount to live longer.
badcatt
« Reply #16 on: October 04, 2026, 10:00:35 PM »
GerryP and cjshaker,
Thanks for the info, I appreciate it. As for a Monti Carlo bar, I have a Scott Drake reproduction export brace. We installed it and it fall into place. That leads me to believe the shock towers are very close to where they belong. I may still try a porta power. I'll keep looking for other ideas as I don't need to get this done tomorrow.
Phil Brown
« Reply #17 on: October 05, 2026, 11:08:01 AM »
It also keeps the clutch linkage happy in a three pedel car  :D
« Reply #18 on: October 05, 2026, 08:56:15 PM »
You're absolutely right. There's a multitude of benefits to keeping the engine from twisting.on stock rubber motor mounts. At the very least, they should be through bolted. It'll save a lot of damage from happening should it break.
badcatt
« Reply #19 on: October 05, 2026, 11:51:00 PM »
I notched the shock tower reinforcement today and now the engine sits down in to place.
https://youtu.be/O3o_VCAAo8E
