Author Topic: TKX into a FE  (Read 3322 times)
Re: TKX into a FE
« Reply #15 on: August 03, 2026, 07:31:00 AM »
It looks like the case on the TKX has a smaller input shaft hole than the TKO600 as why the input doesn't pull out, it must be easier for them to add a plate than a shorter drive input shaft if the shaft is not available anymore,
Thanks for the replies
chilly460
Re: TKX into a FE
« Reply #16 on: August 04, 2026, 07:14:52 AM »
Well, it's certainly not cheap.
https://www.hanlonmotorsports.com/product/tremec-short-input-kit-ford-tkx-p-n-hms-tckt18211/
That said, it's cheaper than a $1300 Quicktime bell.
Re: TKX into a FE
« Reply #17 on: August 04, 2026, 10:04:30 AM »
I haven't done a TKX myself yet, but I do want to point out that it's important to know what short shaft means.
The SBF T-5 and Tremec for the 5.0 had the longest of shafts and pilot tip, then the SBF, then the big blocks.
When I did my TKO, they sold a specific FE shaft and it matched my big in/out RUG-AE2 perfectly.
With all that being said, I did a TKO (no number early one) and cutting the shaft was brainlessly easy.  In a lathe, we took about .500 off the splines, then about the same off the pilot tip.  I'd be hard pressed to find 5 or 600 bucks in the amount of work to do it.
