Author Topic: Cutting valve spring pockets for dual valve springs  (Read 2915 times)
67xr7cat
Re: Cutting valve spring pockets for dual valve springs
« Reply #15 on: July 26, 2026, 11:40:23 AM »
Quote
Any chance you have a part # for that particular cutter? I have an assortment of the cutters for cutting down the guides for seals, but not the one for cutting the seats. Thanks!
I bought it from competition products, but you can find them elsewhere.
PVT4719   Spring Seat Cutting Tool, 1.550"/.630"
PVT4734   Valve Guide Arbor, 3/8" for seat cutting tools
Now this cutter will leave a slight step to the guide so make sure your locator has the right ID to match.
« Reply #16 on: July 26, 2026, 12:10:17 PM »
I'm sure Barry was just trying to be helpful, but go back and read what he wrote. To someone not well versed in all this stuff it could have been taken as a spring recommendation. This is why I asked him the question I did. He hasn't come back to clarify his post and I'm not going to read into his post as to intent.
Btw some builders like when a customer supplies the parts as then they do not have to warrantee them.  Personally I never cared if they do, but if I don't like the parts I won't use them.
Who do you build for?
Brent what is your problem?  I work for myself. Sorry if I offend you. Nothing has changed on here. Is a shame.
I didn't mean anything by it.  I don’t know who you are.  You were the one who said "some builders like when the customers supply parts" then followed that up with "personally I never cared if they do".  It implies that you are a shop owner/engine builder.  Are you?  What's your shop's name?
Is this fecat on the other forum?
« Last Edit: July 26, 2026, 12:42:30 PM by blykins »
« Reply #17 on: August 06, 2026, 12:57:46 PM »
Geeze - it was just an example of something that can work - a clip in part.
Most guys that want to run a factory head without spring pocket modification are going for lower dollar budget stuff.
Something you can do "at home".
You can play with the pressures a bit with spring seats and offset keepers.
But you can't go too far before you run out of "step" as a locator.
If you want to get all fancy and stuff there are lots of "better" choices, but they involve spring pocket cutting and such.
« Reply #18 on: August 06, 2026, 03:00:52 PM »
n/m
« Last Edit: August 06, 2026, 03:22:46 PM by blykins »
