Author Topic: scat stroker crank balance  (Read 5702 times)
Jb427
Re: scat stroker crank balance
« Reply #30 on: July 05, 2026, 12:01:13 AM »
« Last Edit: July 05, 2026, 03:34:07 AM by Jb427 »
pbf777
« Reply #31 on: July 06, 2026, 11:14:08 AM »
     I was referring to the "replacement" they are sending you.   :)
     Scott.
hbstang
« Reply #32 on: July 16, 2026, 08:20:16 PM »
scat ship crank back and shipped another crank to builder.brian balanced it today with no issues.crank was defective,even used less weight to balance it,1 small slug in front and back! happy days.thanks to scat for replacing it,pretty good customer service !
« Reply #33 on: July 16, 2026, 08:33:16 PM »
Awesome news!
« Reply #34 on: July 23, 2026, 07:31:54 AM »
Double check everything first.  But - if it wants weight you're gonna add weight.
We used similar balancer and engine combinations several times and - IIRC - we ended up tossing several slugs at it.
Put a piece of metal in the corners of the counterweights and re-check it.
If you are getting closer you know you're gonna keep adding.
At least once we had to drill through #1 counterweight and add metal to #2 to get where we needed to be.
hbstang
« Reply #35 on: July 23, 2026, 09:18:26 PM »
the first crank was junk and scat swap it with a another new.the pics show 1 slug in frnt and 1 in rear cw,with it looks like holes drilled int them as well.anyway,this part of build is done so glad scat did that.i guess i may post a build thread on this project when more gets done.thanks for all the help!
