Author Topic: End of the Line for FE Power Cast Aluminum Products  (Read 13489 times)
mygasser
Re: End of the Line for FE Power Cast Aluminum Products
« Reply #30 on: April 13, 2026, 08:27:02 AM »
Not clear about foundry costs, but I think this printer is around $40K upfront, but can obviously be used over and over...
https://all3dp.com/4/bigreps-new-one-5x-makes-big-parts-faster-easier-plus-introduces-pellet-extrusion/
That prints in PLA and PEEK which are plastics.
Not suitable for things like intake manifolds and such...
i guess that depends on the plastic used, most modern intake's are some kind of plastic these days. any threads needed are taken care of by pressed/screwed in inserts
neil.
galaxiex
« Reply #31 on: April 13, 2026, 08:53:37 AM »
neil.
Sure, but modern plastic intakes are usually composite and/or glass fiber reinforced nylon made in a mold.
Not sure you could print that...
I for one would not want a plastic intake on my FE...
« Last Edit: April 13, 2026, 08:56:06 AM by galaxiex »
« Reply #32 on: April 13, 2026, 09:41:42 AM »
Every time the topic of plastic intakes comes up I have to laugh about my own experience with them.  Back in 2017 I bought a large 3D printer, with the idea that at some point I could print a plastic intake and test it on the dyno.  I had purchased a spool of PLA plastic printing filament and soaked it in ethanol fuel and race gas, and it held up well for a week, so I bought the printer knowing that at least the fuel wasn't going to melt the plastic.  When I finally got around to doing my cylinder heads a few years later, I started designing and printing intakes for them.
After printing a sheet metal style intake, I put it on my dyno mule and tried to run it.  It was fitted with two big Dominator carbs.  To this day I regret not having a camera in the dyno room to video the results.  When I tried to start the engine at an idle it wouldn't catch, probably (I thought) because of the big plenum in the intake.  So I pumped the throttle a few times, opened it up a little, and hit the starter.  After a couple cranks there was a huge, loud explosion and fireball!  The carbs ended up hanging over the left valve cover, on fire.  The plastic in the manifold was blown all over the dyno room, totally shredded.  If I'd had a camera running, I'd have a million hits on youtube with that video; the explosion was absolutely spectacular!
Red plastic from the intake was blown all through the induction system too.  I had to pull the heads, and pick little bits of plastic out from between the pistons and the top ring on a bunch of cylinders.  Five years later I was still finding little bits of red plastic in the corners of the dyno room from that explosion.
Being a sucker for punishment,  I printed another intake, this time a low 4V intake.  After it was printed I checked to make sure it was airtight.  It was NOT; water poured into the intake would leak out between the layers of the 3D printed plastic.  Obviously, my first intake had a huge vacuum leak that caused the problem.
I took the new intake and coated it on the outside with garage floor epoxy to seal it up.  Then after getting the engine back together I tried again, and this time the engine ran great with the 3D printed plastic intake.  Over the next couple years I kept printing and testing intakes; it only cost about $200 in plastic to print them, and I could make changes to the design on the computer, so it turned out to be the great development tool that I had originally envisioned.  In fact, the 8V tunnel wedge style intake went through three revisions in plastic.  The first one made only 825 HP, but the third one, which was an improved design, made 875.  I was really pleased with how easy it was to tweak the manifolds on the computer, and then get real life data from the dyno which showed any improvements.  I was able to tweak all the manifolds for my cylinder head package to optimize their performance.
I did have one other minor explosion along the way, with another sheet metal style intake.  Despite being epoxy coated, it gave a small backfire that knocked a hole in the plenum.  That huge plenum was just a bomb waiting to go off when you added fuel.  Fortunately, that one was no problem to clean up.
Occasionally I get folks who want to buy a plastic intake from me, and run it on the street.  I won't sell them one; a single backfire will damage the intake and potentially spread shrapnel through the engine.  I think even a modern automotive plastic intake would be a big risk to run on a performance engine, unless it was EFI and the timing and throttle settings were dialed in perfectly.  That is how the major manufacturers get away with plastic intakes; best for folks like us to stick with aluminum.
« Reply #33 on: April 13, 2026, 11:53:08 AM »
Jay, I'm not suggesting this for you to continue in business because I doubt that there is anywhere in the US to even get castings but, I'm curious if you ever investigated magnesium castings and their availability. I can only assume that you'd have to go to Canada to get castings.
Other than there long term corrosion issue with water and possible fire issue with chips (I used to machine it), I think it's the ideal material for the big FE intake, I know that there are mag intakes that have been done, in the past, for FE and others but, nothing I've ever seen in the after market, other than Sprint Cars.
Dumpling
« Reply #34 on: April 13, 2026, 04:32:19 PM »
"BigRep offers a specialized range of high-performance 3D printing filaments tailored for large-format, industrial applications. Key materials include heat-resistant HI-TEMP/HI-TEMP CF, engineering-grade PRO HT, flexible TPU 98A, soluble BVOH, and high-quality PLX/rPETG/rPLA, all designed for durability and precision.
Key Material Properties & Uses:
HI-TEMP: High-temperature resistant, rigid, and low-warp, suitable for industrial, high-heat applications (up to ~100°C+).
HI-TEMP CF: Carbon fiber-reinforced, offering high stiffness ( flexural modulus) an
Urgefor
« Reply #35 on: April 14, 2026, 04:24:28 AM »
I take it 3D printing is not a viable option for making the parts?  I'm aware that some very intricate parts like the one in this video can be made, but I have no knowledge of the costs involved.
So I did a small amount of searching.  Appears to be well beyond EXTREMELY cost prohibitive.  I'm still trying to wrap my head around how manufacturing facilities are justifying something like this (probably still too small for some of Jay's parts) versus having a part cast at a foundry.  Both options require final machining.
Dumpling
« Reply #36 on: April 14, 2026, 06:44:09 AM »
"the influx of metal additive manufacturing. An avid 3D printer can now print in metal with direct metal laser sintering technology. You can easily use Aluminum AlSi10Mg or Stainless Steel 3156L and melt together a brand new cylinder head that would perform presumably exactly like the original head did. It's amazing how far this technology has come. The aluminum 3D prints have a melting point of around 1240 degrees Fahrenheit, for example, and would easily stand up to the temperatures of internal combustion."
Read More: https://www.jalopnik.com/2143679/3d-printed-engine-cylinder-head/
« Reply #37 on: April 14, 2026, 12:00:59 PM »
Aerospace and prototype have moved deep into this.  Low volume or first run stuff where speed of delivery outweighs costs, and/or where the full cost of tooling has to be amortized over a very few parts.
Dumpling
« Reply #38 on: April 15, 2026, 09:33:10 AM »
Cheaper and cheaper;
3D printing metal intake and exhaust manifolds ...
 https://youtu.be/rFhg02wujqs?si=N25Iotlt1tVcCeFM
« Last Edit: April 15, 2026, 09:50:43 AM by Dumpling »
« Reply #39 on: April 15, 2026, 10:36:00 AM »
Not cheap enough; based on the pricing shown in his video one of my intake adapters would be >$9,000 to print.
hbstang
« Reply #40 on: April 16, 2026, 11:11:40 AM »
wow thats not good for fe racers.i guess even your heads and adapters are done?all that work you put it on design and casting machining.maybe some one with resuorces should start a small foundry for all the others who do this.
this place in ohio may be able to help
https://jarvieperformance.com/index.php
« Last Edit: April 16, 2026, 11:05:13 PM by hbstang »
driveamerican
« Reply #41 on: April 20, 2026, 09:44:34 AM »
Thanks Mr. Brown for all the hard work. This is truly sad.
Royce
« Reply #42 on: May 07, 2026, 07:25:50 AM »
Damn, the end of an era.. There goes my plan for Jay to branch out and start producing heads for Y block Lincolns and Fords  And maybe MELS.
2 yrs from now those intake adapters will be selling for a couple grand. People will be talking in hushed tones about the rare and magical Brown head  lol
Hell of a ride Jay
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Hemi Joel
« Reply #43 on: May 09, 2026, 04:17:26 PM »
That's downright tragic in so many ways, Professor Brown. But it will make you life a lot easier not having to deal with it.
