Author Topic: Cooling system that works in traffic  (Read 7334 times)
c9zx
« on: February 12, 2026, 01:23:06 PM »
I'm doing some advance planning regarding cooling. What is everyone using for aggressive street car that works well? Car is 1966 Cyclone, 462, TFS heads, 10.4:1,RPM intake, solid roller cam. Is there anything that work in a near OEM radiator size (the car is too nice to cut on). Two row double pass, 3 row, electric fan(s), custom shroud, etc. All input is appreciated. Chuck (S)
1969 Eliminator G code
CSX-7031 FIA Cobra
2007 Mustang GT, Whipple
1966 Cyclone GT
475fetoploader
Re: Cooling system that works in traffic
« Reply #1 on: February 12, 2026, 03:37:52 PM »
I’m in the same boat as you right now.  67 Fairlane.  I’m going to try a frostbite radiator, cvr water pump, and the Davies Craig water pump/fan controller. Not committed to a fan yet, possibly a Spal.
1967  519 c.i.  TKX 5 speed
FirstEliminator
« Reply #2 on: February 12, 2026, 03:48:56 PM »
   I don't know much, but here are a few thoughts...
While I've had a lot of trouble keeping the 483 in my 68 Colony Park cool. The 445 in my 69 Cougar Eliminator runs like a cucumber. I downsized the bypass to 5/16. Used a new ACP 3 core A/C style radiator. 7 blade clutch fan with a shroud. Run a 180 thermostat.
  Using a heater control valve to stop the return of hot water back into engine helps. If you aren't running a heater core, never loop the heater ports with hose. The heater in the Cougar has constant flow, yet it runs cool enough not to bother with blocking flow. I've found with the CP 483 blocking off heater core flow will make a 10-15 degree difference at highway speed. Blocking that path of heater core will force the a higher percentage of hot coolant to go through the radiator versus being returned hot into the engine. The same idea applies to the downsizing the bypass hose between the water pump and intake. That 5/8 port continually puts hot water back into the engine. You should have some level of flow recirculation to level out temps. Otherwise, when the thermostat is closed the coolant would be too stagnant allowing hot spots. 5/16 seems like a good balance for cars like ours.  Another thing is drilling a 1/8" hole at 12 o'clock in the thermostat. It helps to purge air during initial fill. As long as the bypass isn't blocked, I don't see much other purpose for drilling a hole. I've seen blocked bypass on intakes. It seems you'd need to drill a bigger hole, like 5/16 in the thermostat, or just run a restrictor in place of the thermostat.
   Get yourself some women's leggings, like pantyhose. The other reason for this is to make a sock that might catch any debris that could clog up a core tube. In a freshly built engine, I was surprised how much stuff got caught in there. pieces of RTV, rust flakes, etc. The legging sock will go into the upper radiator port, probably 10-12 inches and then roll back over the spout where the upper hose goes on. The hose will go over the layer of fabric and get clamped in place. It's a temporary thing to do because I found even when the clamp is very tight, it still likes to very slowly weep.
    When the shroud is custom or factory offering, you want the fan engaged 1/3rd in, 2/3rd out. A fan fully in the shroud will spin the air around and move less through the radiator. A lot of the air moved by the fan comes off radially. The 2/3rd out will allow the air to sling off the fan and pull more through the radiator.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
« Reply #3 on: February 12, 2026, 06:04:33 PM »
19X31 aluminum crossflow 2 core radiator (at least 1" core width), two SPAL electric fans, both pullers or one pusher and one puller, depending on fitment issues, 160 degree thermostat with four 1/8" holes around the periphery, and a CVR 55 gpm water pump.  Cools my big SOHC in the race car on Drag Week, never see over 180 unless I'm leaking coolant without knowing it.
Jb427
« Reply #4 on: February 12, 2026, 07:12:20 PM »
I just run a mechanical pump with a small cvf pulley 160 thermostat I also drill more 1/8th holes in it I think I did 2 extra holes + the one hole that came std with mine I use 2 derale fans my radiator is not the best choice but it was what I had at the time it is 29x19 or close to that I am right on the limit of radiator thickness and one day I will change it to a crossflow type and have a much thinner radiator with better cooling. 105 deg c day mine will sit at 190 to 200 @2800 to 3000 rpm on the highway and it will pull temps back to 180 in less then the time it takes for a set of traffic lights to change. My raised highway temps are due to my fan and fan shroud not being deep enough due to space If I could get an inch more depth in my fan shroud I think that would not happen. But it works very well I also have a full opening size A/C condenser in front of my radiator.
3goats
« Reply #5 on: February 12, 2026, 09:54:10 PM »
I have a 66 Comet 4  speed, stock radiator 445 which was overheating. I put these Spal fans in with the senders 185 and the other 190 degrees and in the 3 months that I've ran them never overheated.    https://www.amazon.com/dp/B01E7RMQJE?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_7   I searched around and got the same ones on a different site cheaper.
« Last Edit: February 12, 2026, 09:57:13 PM by 3goats »
Tommy-T
« Reply #6 on: February 13, 2026, 08:04:10 PM »
First of all, no car is too nice to cut.
The motor in my Comet is a D4TE bored .080 and hard blocked to the water pump holes. It has an Eagle 3.980 crank and zero deck flat top pistons. 11.5:1 compression. I live in the high desert above Los Angeles and summertime temps are around 100* sometimes more.
My cooling set-up mimics Jays pretty well, Ebay 19x31 aluminum radiator, Spal dual 11"paddle fans (very noisy but pull a ton of air) 185* & 195* fan sensors, 160* engine thermostat with 2 1/8" bleed holes drilled. The fan that runs on the 195* sensor rarely comes on.
I have a PRW aluminum mechanical water pump and a Volvo 740 Turbo water pump pulley that's 4 3/4" in diameter. 7" crank pulley.
The car does have an engine oil cooler 11"x13" with it's own fan. I was told that a filled block on the street needed one. Installed a oil temp sender in the sump of the oil pan. Highest oil temp I've seen is 210*.
I beat the silly motor like a red haired step child and drive it to car events that are 100+ mile round trips. Run California cat piss 91 octane gasolene,
This thing runs cool and doesn't do anything weird. It amazes me that a motor I put together with parts I had on my junk pile works well. I was sure that it would be a cronic heater.
fairlaniac
« Reply #7 on: February 15, 2026, 11:35:28 AM »
In my '66 Fairlane I used this setup from 2006-2020 with my 390. I used the same set up when I installed a 427 (484 cu/in) stroker.
I used a Howe Racing aluminum radiator by Crites restoration http://www.critesrestoration.com/fairlane.htm (I understand Howe still makes the radiator). This radiator fits the 66-69 Fairlane/Torino/Cyclone.
I used Spal dual fans http://www.spalusa.com/ part number 30102130 and their relay/thermostat controls at  http://www.spalusa.com Quantity of 2, 1 for each fan motor. I had to upgrade to a 130 Amp one wire alternator to accomodate the fan amp draw. I used some old NOS hoses I had lying around to hook up the radiator and water connections.
Upper Hose: D1HZ-8260-A the Motorcraft equivalent is KM-391. Modification: 1" trimmed off both sides.
Lower Hose: C4SZ-8286-A the Motorcraft equivalent is KM-128. Modification:  3/4" trimmed off rad. side.
I have an Edelbrock aluminum water pump. I use the 185 thermostat sending unit.
Here are a couple of picture links.
http://www.fairlanet.com/images/rad01.jpg
http://www.fairlanet.com/images/rad02.jpg
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
c9zx
« Reply #8 on: February 16, 2026, 11:32:03 AM »
Many thanks to everyone for providing helpful and detailed information. It will be helpful in the future. Chuck (S)
CSX-7031 FIA Cobra
1966 Cyclone GT
frankenfords
« Reply #9 on: February 16, 2026, 02:33:00 PM »
My two cents on this, having lived in Southern California, where fuel quality and traffic flow sucks while ambient temperatures can be stifling, my whole life, and having built and daily driven some not quite practical for daily driver status combinations, tune up is essential.
Run as much static initial timing as you can get away with. It absolutely makes a difference in engine temperatures. I’ve regularly had to run initial timing in excess of 20 degrees to get a strong idle and not overheat. As long as you have a clutch or a loose converter, the engine doesn’t try to diesel when you turn it off, amd you don’t have warm start issues, you’ll be good.
Beyond that, a quality, stock replacement big-block or air conditioning sized radiator with no blocked tubes, either aluminum or copper and brass (I’ve successfully used both recored factory and stock replacement Griffin or Cold Case, none of that champion brand stuff…), a factory style fan shroud, a factory air conditioning or smog era 6 or 7 blade thermostatic clutch fan, a 180 degree thermostat with one or two 1/8” diameter burp holes drilled, and a slightly underdriven (yes, underdriven) high quality (Edelbrock, Milodon, Stewart, or Flowcooler) water pump works for me. Use just enough antifreeze to prevent corrosion, water cools best. Having at least a liter sized overflow or burp tank keeps water off the pavement when the temp spikes after a hot shut down, allows the cooling system to draw it back in. The little import car section at the pick-a-part is a good source for the overflow tanks, early 90’s Geo Prizms have my favorite with a nice little bracket that allows you to pull it out and flush it.
As with all advice, your results may vary, but decades of trial and error have brought me to the above…
« Last Edit: February 16, 2026, 02:42:15 PM by frankenfords »
