Author Topic: fe powered 58 rambler american gasser  (Read 23229 times)
mygasser
Re: fe powered 58 rambler american gasser
« Reply #45 on: May 06, 2026, 11:16:26 AM »
i needed carbs for the tunnel ram and as it'll be almost exclusively a street car they needed to be a) smallish and b) holley's as i prefer/understand them. so when a small block ford polished tunnel ram came up with a pair of 390's on i did the obvious thing and tried to buy just the carbs. no dice there so i bought the lot and have advertised the manifold and filters for sale.
neil.
forgot to say they came with 2 boxes of holley jets too so that'll help with setting them up for my fe engine.
1964Fastback
« Reply #46 on: May 06, 2026, 11:29:46 AM »
I like the idea of a street tunnel ram.  :)  I don't think I'd tee them into the metering block like the seller did, though.  That's for the spark advance and the vacuum secondaries should open by passages already in the secondary housings.  I think with them teed into the block, they would either open too soon or (more likely) not at all.  Just use a single vacuum line to connect the two caps together and plug the ports on the metering blocks, or hook the primary one to your distributor advance.  My 2 cents.
Pat
mygasser
« Reply #47 on: May 06, 2026, 03:20:16 PM »
Pat
i've had a few tunnel rams on street cars, a couple were my daily drivers. mpg wise they're not much different to a single plane with a single double pumper in my experience. i mean most of the time on the street you'll only run on the primaries which then behaves like a double pumper right? they are good when set up right and nothing like the naysayers preach about them (maybe they can't/won't set them up right?). the myths about high rpm only race intake are just that.... myths. the long runners make good torque lower down in much the same way gm's tpi set up did in the 80's.
neil.
mygasser
« Reply #48 on: May 12, 2026, 08:42:30 AM »
the howards hyd' roller lifters arrived today from summit. i also ordered a pushrod length checker ready for mockup time.
neil.
mygasser
« Reply #49 on: May 26, 2026, 10:35:25 AM »
i'm looking into the fi-tech 2x4 efi to go on my tunnel ram in the future. i'll initially go with the pair of 390 holley's i've just bought but as (dare i say it) i want the nash to be a keeper i will swap to efi at some point over a winter. at least the holley's will sell easily as they're always in demand for rover v8's  ;D
neil.
mygasser
« Reply #50 on: May 27, 2026, 09:47:31 AM »
i've done more digging and i won't be going with a fitech efi setup. the holley systems seem to have much better reviews and for the little extra it costs i'm favouring the terminator x version. any thoughts on those?
neil.
« Last Edit: May 27, 2026, 09:49:02 AM by mygasser »
« Reply #51 on: May 27, 2026, 01:00:48 PM »
neil.
I haven't used a dual quad Terminator X, but have with an 8 stack, and the programming is easy.  It's same on Snipers just more adaptability, which I have used many.
I will say this, on every single Holley harness, I sit on the couch with my wife and verify colors at the various connectors before install.  I had one on the dyno that took two days of messing around.  That harness had the handheld wired backward and separately, it had the cam and crank sensor swapped in the connector.  I haven't had any wired wrong since then, but it was such a significant event I check every wire now
mygasser
« Reply #52 on: May 27, 2026, 07:02:13 PM »
thanks for that.
in the mean while i've ordered a 110gph, 7psi electric pump to feed the two 390 holleys i'll be using for a start.
neil.
mygasser
« Reply #53 on: June 10, 2026, 03:34:15 PM »
well this is a turn up for the books, our 15 year old grandson (who lives with us) wanted to do his 'work experience' in my garage working on old/custom cars  :o  ;D. he learned how to fit nutserts today.... and how to run out halfway through the job  :-[ amazon will have them here tomorrow so until then he may have to learn/observe how to weld  :)
neil.
mygasser
« Reply #54 on: June 10, 2026, 04:03:27 PM »
also today i ordered the steel we'll need to push the left side of my garage out to almost the house (replacing what we call the 'side shed'). it'll give us about an extra 7 feet in width from the front to a foot or so past the left ramp post. we'll get my mate the steel fabricator to fold the box gutter in his big (10 foot long) folder from galvanised sheet so there'll be no overflow issues there. the gutter will probably be at the 'join' between the edge of the current garage roof and the new extension roof. we need somewhere for another bench that we can mount the shrinker/stretcher, english wheel and bead roller to amongst other things plus it'll give more room to work that side of the shop.
neil.
mygasser
« Reply #55 on: September 17, 2026, 07:34:04 PM »
further to the 390 build for my nash, i just ordered a set of standard size hyperutectic 360 pistons and rings, a full felpro gasket set and 10 under rod bearings. i'll have one of my 352 blocks bored to 360/390 bore size and the crankshaft ground to suit the 10 under bearings (i already have 10 under mains here). if the crank won't clean up at 10 under i also have 20 under rod and main bearings so we're covered.
mygasser
« Reply #56 on: September 18, 2026, 09:47:55 AM »
the plug leads arrived today so they're now cut to length with the ends crimped in place. with a bit of tweaking of the timing (we only rough set it) it fired into life. of course it's loud and it sounds a bit rough, but considering it had sat for god knows how long and was 'stuck' when it first got here it's not too bad. the battery is on charge as it was getting a bit slow so that's it for now. terri took a video on her phone so i'll add it once she's sent it to me.   :)
neil.
mygasser
« Reply #57 on: September 19, 2026, 09:03:13 AM »
mygasser
« Reply #58 on: September 23, 2026, 05:58:31 PM »
bits are trickling in for my 390 engine build.
the pistons, rings, big ends and gasket set arrived today. i need to get both crankshafts (352 and 390) to the machinist and a block to a mate for the rebore.
neil.
mygasser
« Reply #59 on: September 24, 2026, 04:19:17 PM »
so the 360 engine will go over the road until i can afford a rebuild/stroker kit/ally heads. it wouldn't 'tune' to run better so a compression test was next up......... oh dear. they varied from 55psi to 80psi so that's no good then. the run stand is now stripped apart and the engine will be off the build stand tomorrow so we can make room to get on with the wolseley.
neil.
