Author Topic: Controlling windage. Building a Crank Scraper for the 2.8l Ford v6  (Read 3830 times)
mummert
You have to click on the link to see it.
https://youtu.be/A8CarmN4tL0
« Last Edit: January 05, 2026, 02:44:33 AM by mummert »
Re: Controlling windage. Building a Crank Scraper for the 2.8l Ford v6
« Reply #1 on: December 18, 2025, 12:53:12 AM »
Not just 2.8 but how much horsepower can you pick up with a widage tray or scraper. Do you think the more horsepower you make the more important widage is?
mummert
« Reply #2 on: December 18, 2025, 01:38:25 AM »
  Absolutely, big blocks with stroker cranks are horrible.  We've played with a 4.25" stroke 460 base engine that is a nightmare. With all kinds of tricks that ting is sensitive to 1 qt. of oil on the dyno.  With 8 qts of oil in a pretty good pan, engine makes good power and oil pressure fall off 6-8 psi from 6500-7500.
 With 9qts its loses 15hp and the oil pressure falls off 12-16 psi from 6500-7500 :o
 The 2.8 is a short stroke in a pretty big crank case.  The HP gains won't be huge.  But I'll take 1.5-2% where I can get it.
