Author Topic: 73-79 F100/150 2WD Crown Vic front swap with FE. Anyone do this? Header choice?  (Read 5554 times)
fairlaniac
I am putting a Crown Vic front crossmember and suspension on my 78 F150. I plan to drop a 390 stroker in it. Nothing too high Performance just dependable and it’s gonna be more of a beater truck than anything. Looking to see what headers others may have used. I am also using the Outcast engine mounts. I saw a 10-year-old YouTube video with a similar installation, but they never mentioned which headers they used or make or application in the video. Thanks!
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
fomocoloco
any headers designed to fit your truck will fit. the crown vic k member installation will not cause a problem. currently i'm working on my # 8 crown vic ford pickup install. like anything else the more you repeat something the easier it gets.
jim oberg
8 65-72  f100 sb trucks 5 428's 1 460 2 521 strokers
1 66 f100 lb ranger sold
3 67-75 f350
numerous parts vehicles and parts
88 tbird 482ci 427 stroker 6R80 project
fairlaniac
Thank you Jim, that is good t o know.
Doug Bender
1978 F150 2WD 390
cleandan
The only big concern is which headers to use depending on exhaust port location for the heads of choice...otherwise they will fit the chassis.
Dr Mabuse
... I plan to drop a 390 stroker in it. Nothing too high Performance just dependable and it’s gonna be more of a beater truck than anything ...
With your application, it sounds like the reproduction 428 CJ cast iron exhaust manifolds would be perfect. Easy installation, reasonable price, quiet, never rust out:
https://www.cjponyparts.com/exhaust-manifold-pair-428cj-1968-1970/p/EXM5/?gad_source=1&gad_campaignid=19712467657&gbraid=0AAAAAD1v5VkjRnrRtu058j8tq_RuETPGW&gclid=Cj0KCQjw-ZHEBhCxARIsAGGN96LgH-ZeHSC52CAg7-3XYCEiZRerbqhBZBM38NS_2hXM3Hj96tTGy00aAk7rEALw_wcB
