Author Topic: TFS Tunnel Wedge Carb options  (Read 16971 times)
GerryP
Re: TFS Tunnel Wedge Carb options
« Reply #15 on: July 09, 2025, 06:02:31 AM »
There is a metering plate conversion that maintains the short profile of the plate and uses screw in Holley jets.
TurboChris
« Reply #16 on: July 09, 2025, 03:44:30 PM »
That would be the 34-2QFT Billet Metering Plate Kit, I have a pair sitting in my garage waiting to install.
« Reply #17 on: July 09, 2025, 04:21:16 PM »
This is the difference between the replaceable jet metering plate and the after market metering block.
There is no comparison to the tuneability of the blocks vs the plates.
While many won't need it, there are very many that would love to have the blocks, with the down the road tune or dyno session, in mind. Not to mention, engine compartments are full of things the the owner don't need but, they want it.
Jb427
« Reply #18 on: July 09, 2025, 05:56:30 PM »
I run 2 715cfm quickfuel's from sp carburetors Lykins motorsports supplied mine just sent him my engine specs and I have not had to do anything to them so far my engine is 482ci i use a bbm tunnel wedge 1 inch spacers.
6667fan
  • Every Second Counts
« Reply #19 on: July 13, 2025, 09:56:11 PM »
Same as JB427, 715 carbs via Brent’s guy. (SP)
Mounted on Dove TW
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
427LX
« Reply #20 on: July 21, 2025, 01:15:41 PM »
What style spacer you run...4 hole or the 4 hole merge...Super Sucker?
Jb427
« Reply #21 on: July 21, 2025, 02:45:03 PM »
HVH Super suckers part #SS4150-1ALW
427LX
« Reply #22 on: July 21, 2025, 04:17:03 PM »
Thanks
