Author Topic: When to shift  (Read 18940 times)
Ratbird
Re: When to shift
« Reply #15 on: December 10, 2013, 11:15:14 AM »
Thx gents, all great info.
I think mine is fairly similar to yours Jim. I told the builder it was just for fun, and that I wanted a tire spinning street car. It's just a fun Ratrod type T-bird that I cut a hole in the floor for a 4 speed. I fell in love with the idea of a 390 with a longer stroke after reading a bunch of stuff on the interweb. They all say torque is what'll move a heavy car. The builder told me that it was basically a 66, 67 Merc 410. It was bored .030. Has c4ae heads with CJ exhaust valves (stainless steel) and comp springs. I didn't know anything about "shimming" so I asked the builder after I read it on the build specs. He said something like it makes all the valves perform the same (evenly) and will help stop valve float. He used a CJ cam. It idles OK at 650 rpm. The CR is 10.5 and runs fine on 91 octane. I had found an RPM Performer intake. I put a Edel 750 with the appropriate jets and metering rods for our altitude. I also have FPA headers, they are the only ones I could find for a 59 T-bird - they were pricey but really well made. He said it would probably be in the 375 to 400 hp range and torque would be in the 450 range. The car weighs 3800 without me.
What does .050 quench and 7.5 DCR mean? Also, what is desktop dyno? I'm guessing that's software for estimation purposes?
My rearend is a 3.89 one wheel turner. Once I break in the motor and clutch I will see how the wheel spins and hopefully get a limited slip 3.50 to 3.70ish pumpkin. I want to be able to drive it 90 miles to Albuquerque sometimes. I might buy a used trailer and tow it. If I do I'll go with a lower rearend.
I had a hard time setting the timing and I'm still tuning it. The builder told me the timing should be about 10-12 and that it should never go over 38 total. I think I might start a whole new thread on that when I get some warmer outdoor temperatures and can work on it.
thx, Dave J
pure fun
JimNolan
Re: When to shift
« Reply #16 on: December 10, 2013, 12:13:49 PM »
thx, Dave J
Dave J,
    You need to figure out first what you want your car to do. With a four speed transmission you have to make a choice. When I restored my 57 Fairlane the first thing I did was design it. I wanted drag racing fun AND touring economy and smoothness. That's why I went with a Tremec TKO 600 with a 3.50 Tru-Trac. I cruise at 65mph and 1850 rpm getting 16 mpg and I can't put big enough tires under my car to keep it from spinning when I get on it. My advice to you with a 4 speed is to make a choice. Since I enjoy driving my car and going on trips I'd choose a 3.25 rear gear ratio at the most. But, if you like cruising down the interstate with your engine turning 3000 rpm, go with a lower gear.
Quench: That's the distance between the top of the piston and the bottom of the head with the head gaskets installed. You can go down to .040 at a minimum and .050 at the most to achieve a more complete gas atomization that will enhance the combustion in the cylinder and lower your needed octane level per compression ratio used. In other words it will help minimize spark knock when using lower octane fuels with higher compression engines.
DCR: Dynamic Compression Ratio is the actual compression ratio the engine sees. You need to look this up on the internet to fully understand it but in summary it's the compression ratio with stroke measured after the valves are fully closed on the compression stroke.
On both my 406 and 410 the Quench and DCR were designed into the engine before the cam, pistons or head gaskets were chosen. That's why I can burn 87 octane with a 10.5 CR, .042 Quench , 7.6 DCR 406ci engine and a 9.5 CR, .050 Quench, 7.5 DCR 410 ci engine.
Timing: My 410 ci engine has an initial timing of 14 degrees and a total of 38 degrees. The 406 ci had to be set at 17 degrees initial with a total of 34 degrees. The 406 had to have an ignition system that retarded the timing 5 degrees to enable the use of a stock starter though. You can't start a FE engine at 17 degrees, not very well anyway. I hope this helps.
PS The 406 engine was initially designed to drag race. I built the engine before I got the car from New Mexico. The car ended up being too nice to cut up so I changed the ring and pinion in the 3.50 Tru-Trac I'd previously bought to a 2.75 gear ratio. I also had to change the cam in the engine and turn the vacuum screw back in the Jay Broader transmission so it wouldn't jerk your head off during slow speed shifts. I get 14 mpg with that engine and I cruise at 2150 rpm at 65mph. I had to make a choice with that car because I didn't have a transmission versatile enough for touring and drag racing. I can barely spin a wheel with that car (406).
« Last Edit: December 10, 2013, 12:33:28 PM by JimNolan »
Ratbird
Re: When to shift
« Reply #17 on: December 10, 2013, 06:03:21 PM »
Thx again Jim,
As for my car I guess the end project in my head is something like you described with your 57 Fairlane. However I don't care about gas mileage just as long as I can run it on pump gas. I'm not going to put more than 300-500 miles on it each year so the $ in gas won't be that big of a deal. Doug Anderson in Albuquerque was the builder. I told him that, and I also told him I wanted a fairly rowdy cam, but he suggested I keep the cam calm enough to give me vacuum for the front disc brakes. Doug is an old FE guy through and through. Bn69stang tells me that Doug owns an original T bolt.  I told him basically what I wanted it to be, but I'd like his recommendations.
My plan for the car was a retirement project in 4 years. However I started playing around with it in my spare time and now I'm having too much fun to quit! With that, I decided to make it run and then do upgrades here and there as money and time permits. I started with an unknown 390 out of a 67 LTD. Got that running and drove it some throughout the summer but I fried the clutch and decided to have Anderson's shop build my motor. Next will be the rear end, after that some head work, then the Tremec most likely, but all that will be over a few years time. For the next 12 months I'll have to deal with 55 mph at 2500 rpm on the interstate if I decide to take it anywhere. The body and interior will be original patina by father time and mother nature.
If you're bored or interested in a very amateur project you check out pictures and descriptions at this link.
https://picasaweb.google.com/101492851059660555641/StreetRatProject?authkey=Gv1sRgCJSKjNbR6eunsgE
thx again, Dave J
pure fun
Hemi Joel
Re: When to shift
« Reply #18 on: December 12, 2013, 07:01:27 PM »
When the fender starts to lay down - SHIFT!
Joe-jdc
Re: When to shift
« Reply #19 on: December 12, 2013, 10:12:16 PM »
If you have the torque to pull the load, the sooner you shift the quicker it will be--if not, then you need the horsepower to pull you, and then you need to go past the recommended rpm of the camshaft by 200-300rpm, but not let the engine pull down below the torque band on gear changes.  Sounds simple, but it tough to actually do.  Another way is to gear the car so that it maxes out the rpm just at the stripe.  Joe-JDC
Ratbird
Re: When to shift
« Reply #20 on: December 13, 2013, 11:47:30 AM »
Thx Joe, the idea behind this motor was to have the best of both worlds. Some articles I read said that an FE can have the torque at lower rpm and hp at higher rpm. That's what I told the builder I was hoping for.
Something I didn't know, (because I only started looking at, and understanding cams) is that my cam is a Lunati CJ. It has more duration than a stock CJ cam. It's range is stated as 3000-6000. I'll have to finish breaking in the clutch and motor before this spring and then find a nice quiet road to do some test driving.
I'll also look on line and see what I can learn about a rev limiter. I know nothing about them but I think I know what they do.
Appreciate all the input!
Dave J
pure fun
