Author Topic: BILLET SPEEWORKS MAIN CAPS  (Read 31349 times)
428 GALAXIE
Re: BILLET SPEEWORKS MAIN CAPS
« Reply #30 on: September 24, 2025, 10:58:38 PM »
« Last Edit: September 25, 2025, 02:47:29 PM by 428 GALAXIE »
Mikko
bluef100fe
« Reply #31 on: October 22, 2025, 12:56:55 PM »
So the caps are being machined at Straightline Machine LLC right now. Just did a test fit of the first cap off the machine on a stock 330 MD block I got here . How much material would you guys like left in the bearing journal area? .005/.010/.015/.020? I can change the cutter comp and adjust it somewhat. I’m also wondering if I can add the reliefs for the bearing tangs for Cleveland and FE to the cap, I think they are located differently. First batch only had the tang relief for FE.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
c9zx
« Reply #32 on: October 22, 2025, 02:04:34 PM »
Cody, I called and left a message. I still want a set. Chuck (S)
1969 Eliminator G code
CSX-7031 FIA Cobra
2007 Mustang GT, Whipple
1966 Cyclone GT
« Reply #33 on: October 22, 2025, 07:44:25 PM »
.010" undersize for the main bearing bore is about right for most shops with line boring equipment...
bluef100fe
« Reply #34 on: October 23, 2025, 07:25:02 AM »
So I’m thinking I’m going to error on the fat side… the registers on these blocks seem to be close to the same size in width.. not so much for location. Swapping one cap between a couple different blocks and block registers seems to show variance on location. I can’t see leaving more than .020 or so but these blocks seem to be all over the place so that’s probably as close as I want to cut the caps without having the block on my shop floor to custom fit each one. Step by step they are coming along nicely! I wish I could still post pictures here. We will see if this link to Facebook works https://www.facebook.com/share/p/1CxxYaRrQt/?
« Last Edit: October 23, 2025, 07:26:57 AM by bluef100fe »
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #35 on: October 23, 2025, 09:59:01 AM »
Cody, I can see the post on Facebook, but I’m not seeing the pictures of the caps on any of the various pages. The pictures might be there, because I see somehow one of the commenters had a picture they referenced. Maybe a person might have to be friends with you?
Do you want to try sending me the pictures on Facebook messenger, and I can post them for you here?
Thanks for tackling the project, there’s definitely a need.
bluef100fe
« Reply #36 on: October 27, 2025, 09:24:58 AM »
Hey Kevin, if you want to post some pictures of this project that would be great, I can’t seem to find your email address or how to get to it on here.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #37 on: October 27, 2025, 09:38:33 AM »
I sent you a message with my email.
« Reply #38 on: October 27, 2025, 11:07:25 AM »
Here are Cody’s pictures of the caps. (They look nice!)
bluef100fe
« Reply #39 on: October 27, 2025, 12:16:58 PM »
Last two pictures of the dirty fingers holding the bearings is the different tang placement between the 351 Cleveland bearings and the standard FE bearings. I’m going to try to land the tang relief to catch both. The Cleveland race bearing seems to be a bit narrower than the standard FE main bearing. These are both King brand bearings BTW.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
bluef100fe
« Reply #40 on: October 31, 2025, 02:48:43 AM »
Post for the caps I’m making is up in the private classifieds section. I’m not sure if I qualify for vendor classifieds just yet so I located it in the private section. You’ll find more details and pricing there. Have a good weekend!
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
