Author Topic: funny issue fe motor  (Read 14140 times)
GJCAT427
Re: funny issue fe motor
« Reply #15 on: August 19, 2013, 05:24:06 AM »
Jay, do you happen to have the part #s for those bypass units? Thanks
Qikbbstang
on the rear bowl. Then run the return line to the tank off the new rear bowl.
GJCAT427
« Reply #17 on: August 19, 2013, 04:42:08 PM »
I`m running dual 4s so I need to put it before the line to the carbs like some of the GMs did in the early 70s
« Reply #18 on: August 19, 2013, 07:20:46 PM »
The Moroso unit is #65145.  Aeromotive has a ton of different regulators; for a carb #13301 will work.  EFI systems will require a different regulator, like the Aeromotive #13101.
