Author Topic: 427 Automatic  (Read 6735 times)
Royce
427 Automatic
« on: December 24, 2024, 11:45:41 AM »
Did Ford ever put a C-6 behind a 427?
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
gregb
Re: 427 Automatic
« Reply #1 on: December 24, 2024, 12:05:52 PM »
68 Cougar.....
Re: 427 Automatic
« Reply #2 on: December 25, 2024, 06:12:25 PM »
What was behind the automatic T Bolts
Re: 427 Automatic
« Reply #3 on: December 25, 2024, 08:43:32 PM »
A special version of the large case 430 Lincoln HX cast iron Cruise-O-Matic with a unique HX-7976 convertor housing (bellhousing) to mate it to the FE. Same for the automatic equipped Lightweight Galaxies I believe.
Re: 427 Automatic
« Reply #4 on: December 25, 2024, 08:53:12 PM »
And similar for an automatic equipped 427 Cobra
4twennyAint
Re: 427 Automatic
« Reply #5 on: January 03, 2025, 05:38:46 PM »
I think Ohio George had the same trans behind his Supercharged SOHC.  Thanks for sharing the article!!!!
1969 Torino Cobra, SCJ 4.30, 4spd under restoration
1964 Fairlane, 428, 4spd, 4.10, 11.63@119 race trim
1966 Fairlane GTA, 482, C6, 3.50, 11.66@117 street trim
Re: 427 Automatic
« Reply #6 on: January 03, 2025, 07:34:58 PM »
To add a little to this trans, I had a '58 410 MEL and used that large XH case in my '60 Galaxie, in back of a 300 horse, 352.
The early MEL bells bolted to the FE and the 410 version, at lest, had the 31 spline out put shaft. I know that because I had to shorten the MEL drive shaft, to fit my wheel base.
Katz427
Re: 427 Automatic
« Reply #7 on: January 04, 2025, 11:08:06 AM »
According too Ohio George, he started out adapting his hydro-Stick transmission to the SOHC. THE problem was the Willys was a real handful with the SOHC ,engine, so Ford's Charlie Gray told him they would build a C6, so he could keep both hands on the steering wheel. He used a C6 after that in the Willys and the Mustang. George said it shifted gears at over 8000rpm, and was reliable.  I believe Gas Ronda's Mustang also had a C6 behind the SOHC.
George was a good talk at the Fe reunions, and  he told me the Mustang was like driving a Rolls Royce, down the track compared to the Willys. The Willys is in the Henry Ford museum collection.
« Last Edit: January 04, 2025, 01:26:52 PM by Katz427 »
hbstang
Re: 427 Automatic
« Reply #8 on: January 05, 2025, 01:09:16 PM »
thank you for posting this info on t-bolt automatics.always wonderd what they used for them.also very cool cobra automatics !to bad they didnt have a 3500 stall converter and trans brakes,everybody would have been crying over a 10 second t-bolt!
Re: 427 Automatic
« Reply #9 on: January 08, 2025, 03:04:23 PM »
Those early transmissions were a Borg and Warner design automatics MX FX FMX and other manufacturers used them too
