Author Topic: Duraspark Distributor restoration  (Read 3359 times)
fairlaniac
« on: November 01, 2024, 06:38:13 AM »
Actually just a clean up. I'm dropping a 390 in a '78 F150 and plan to use this Duraspark electronic distributor. I have the gear and lower collar off. Should the shaft push out the top? There is some resistance. Not sure if gunk build up or something else. I don't want to force it and break or bend anything. Does the reluctor just press off an on? How do you know how far the reluctor goes on the shaft at reassembly? Are there any good exploded diagrams available?
thanks,
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
rockhouse66
Re: Duraspark Distributor restoration
« Reply #1 on: November 01, 2024, 07:07:51 AM »
Yes the shaft just slides out after removing the gear and collar.  And "gunk" can make this difficult.  You can use a press to get it most of the way out and it helps if you twist and pull at the same time.  There is a clip at the top of the shaft that retains the reluctor.  Fiddly to remove.
Jim
fairlaniac
« Reply #2 on: November 03, 2024, 07:52:23 PM »
Thank you!
Doug Bender
1978 F150 2WD 390
