Author Topic: Front cover alignment with oil pan surface  (Read 6145 times)
Re: Front cover alignment with oil pan surface
« Reply #15 on: August 22, 2024, 12:56:55 PM »
Ben---
I noticed in your post above a reference to the 'bolt torque' of the pan to the front cover.
When I worked at T&C Livonia, I was, very peripherally, involved in an engineering study of bolt torque values where a compressible gasket was involved. The conclusion from the study was that there really is no such thing as a sustained torque value under such conditions due to the infinite 'give' of the gasket material. I agree on the suggestion, above, of the use of studs. (I make them from stainless 'all-thread'.) And a small 'oomph' is just right when using a 3/8ths-drive socket and ratchet. ;)
Boiler Ben
« Reply #16 on: August 30, 2024, 06:32:51 AM »
The cover is back from the machine shop. They took off 0.045 from the flange and it looks perfect.
