Author Topic: New Meziere Polished Water Pump  (Read 4903 times)
« on: June 02, 2024, 04:10:58 PM »
This is a WP170U pump.  It's brand new, I bought it for my Tunnel Port last year, but didn't use it.  I don't have the box.
This is $573 at Summit.  I'll sell for $475 plus the ride.
Re: New Meziere Polished Water Pump
« Reply #1 on: June 09, 2024, 08:38:44 PM »
Besides a few horsepower does an electric pump cool better.?
« Reply #2 on: June 10, 2024, 07:07:11 AM »
They're worth about 13 hp from what I've seen on testing.
As for cooling better, I don't know if I would necessarily say that, but the best "pro" about them is that you can cool the engine down with the engine shut off.
« Reply #3 on: June 10, 2024, 04:36:30 PM »
I've always been a fan of electric pumps because when the engine is at idle, the pump is running at full speed.  That makes them cool a lot better than a stock pump running at idle speed, in my  experience anyway.  I have also seen about 10HP difference with the electric pumps, because after you get past 3000 RPM or so it takes about that much power to turn the stock pump.  See my test results in the graph at the link below.
https://www.fepower.net/Products/cvradapt.html
« Reply #4 on: June 11, 2024, 10:20:06 PM »
10 to 13 horse is nothing to sneeze about didn’t know it was that much. And I do like the idea of circulating the water while the car is off.
« Reply #5 on: June 12, 2024, 02:45:08 PM »
You need this one!
HarleyJack17
« Reply #6 on: June 12, 2024, 03:34:23 PM »
You would not be interested in a trade would you? Canton FE 4x4 Oil Pan and Pickup. One Dyno Run.
https://www.summitracing.com/parts/ctr-16-870
« Reply #7 on: June 13, 2024, 04:50:06 AM »
Unfortunately, I don't need an oil pan like that right now.   But I'll make you a good deal on the pump.
« Reply #8 on: July 10, 2024, 03:56:11 PM »
Sold...
