Author Topic: 6 weeks till DRAG WEEK  (Read 13909 times)
Re: 6 weeks till DRAG WEEK
« Reply #15 on: July 31, 2013, 01:24:49 PM »
I allso have a mopar hotrod .A 25 Chrysler phaeton.
 But i have Fordified it ;D Y-block, Rug trans 9 in rear
Ford 35 front axle  and a 28 Ford grill shell
Hemi Joel
« Reply #16 on: July 31, 2013, 03:42:00 PM »
Meow Kevin, The cage is inspected and certified, I think it is good to 8.50. I just want to get into the high nines,  and have it stay fun and reliable.
427: Hemis need 8 PCV's with all the blow by... ;D
Jay - I was thinking that if I went with the tunnel ram, it would need something 60's  vintage and different on top of the carbs. Velocity stacks seemed too 70's. Then I remembered that I saw some scoops like this on some 60s show car back in the day, maybe a barris car or something, and a search on ebay turned up this pair. And you're right the Hot ROd class at DW needs dressing up a bit. I'll try!
Heo - a Y block in a Chrysler? Well, that's way better than putting a scrub in it! Have you guys discussed scrubs here?
« Reply #17 on: July 31, 2013, 04:27:37 PM »
Yes i built it from leftovers i had laying around
I Think if i use all of its 164.328 truck hp the
et will be lower than 20 sec ;D ;D
the headlights are from a 35 scrub truck
« Reply #18 on: August 01, 2013, 04:22:30 PM »
Very nice, Joel! Love the carb scoops, the wheels and wide whites. Except for the 4-link, it looks like it's straight out of a '50s Hot Rod. The cage looks pretty darn stout, especially with the double supports at the back. Is that a 392 or 426? 9s in that thing would definitely be....um, interesting :o
And I have to ask....what is a scrub? That's a new term on me.
« Reply #19 on: August 01, 2013, 05:22:25 PM »
Around these parts we don't use the "C" word ( rhymes with heavy ) The word Scrub is substituted. If you look at some of the dictionary definitions I think you will see it is a perfect fit:
Scrub:
An animal of inferior breeding, mongrel.
Anything undersized or inferior.
Stunted or undersized
Composed of substitute  or untrained players ( sports )
« Last Edit: August 01, 2013, 05:36:38 PM by thatdarncat »
« Reply #20 on: September 04, 2013, 10:03:47 AM »
Any update Joel? Did you "work at the speed of Brown" and it's ready for DragWeek?
