Author Topic: HYD Roller Lifter Problems - Powell Machine You Tube.  (Read 17645 times)
Re: HYD Roller Lifter Problems - Powell Machine You Tube.
« Reply #30 on: April 05, 2024, 06:04:39 AM »
Note - Hot vs cold lash on this iron/iron 351C is the same.
That's the way it is on FE's too.  I've never seen lash change between cold/hot on an iron/iron combo.
I have.  But it's not a lot.  Maybe .003-.004 max.
« Reply #31 on: April 05, 2024, 10:33:49 AM »
With iron block and heads, I have seen next to no change in valve lash, when using stock type iron adjustable rocker arms, but with aluminum roller rockers, I have seen a difference of .002".
