FE Technical Forum
Minimum thickness of bottom of valve reliefs to piston bottom
Topic: Minimum thickness of bottom of valve reliefs to piston bottom (Read 2039 times)
winr1
January 27, 2024, 10:21:23 PM »
Read on more than a few sites but wanted yalls opinion
Thinest point of valve reliefs to bottom of pistons
Forged pistons.... around 10.3/10.5 .... naturally aspirated
Ricky.
Administrator
Re: Minimum thickness of bottom of valve reliefs to piston bottom
Reply #1 on:
January 28, 2024, 10:21:47 AM »
I've measured a few of my CP pistons, they are always at about 0.200".
Reply #2 on:
January 29, 2024, 08:26:22 AM »
You can get quite a bit thinner in "small areas" on N/A applications.
I've seen .130 at the point - I've always heard guidance of .160-.170.
Problem is that small areas can become big areas if they open up from a bad tune or...way better to be safe.
winr1
Reply #3 on:
January 30, 2024, 12:51:25 AM »
Many thanks yall
Ricky.
FE Technical Forum
