Author Topic: Intake gaskets  (Read 4847 times)
sixty9cobra
Intake gaskets
« on: December 06, 2023, 05:14:31 PM »
I have been using a bit of oil this year mild driving not beating it too hard. I have a TKO600 so I'm not revving past 2500 cruising. The motor does run hot 200 210deg I have to admit, and I will be addressing that very soon. I've discussed the radiators and fans with Jay and Stangman. I hope its the intake gaskets the car runs good has a .700 lift roller cam about 620 hp flywheel. I noticed blue smoke during high vacuum conditions and the plugs look fine last time I changed them. Tailpipes are wet and oily which concerns me. My question is when I pull it apart what's the best intake gaskets for Barrys Proport heads? I bought some red rubber gaskets from Barry Yrs. ago but they are no longer available.
                                                       Harry
Urgefor
Re: Intake gaskets
« Reply #1 on: December 07, 2023, 03:42:21 AM »
I'm a fan of the cometic gaskets.  Varying thicknesses available as well.
sixty9cobra
Re: Intake gaskets
« Reply #2 on: December 07, 2023, 06:17:51 PM »
Thank you for the link. I wonder how easily they can be trimmed?
Re: Intake gaskets
« Reply #3 on: December 07, 2023, 06:53:52 PM »
I have been having my own made.
Similar material to the BT ones I used to get (not quite as nice but same mgr)
send me your address and Ill send you a pair
sixty9cobra
Re: Intake gaskets
« Reply #4 on: December 21, 2023, 11:14:20 PM »
I got the gaskets Barry Thank You they look great.
sixty9cobra
Re: Intake gaskets
« Reply #5 on: February 27, 2024, 03:43:09 PM »
Looks like my oil burning situation is caused by printo leaks number four intake gasket is sucked in. I looked down the intake with a bore scope. Spark plugs show no oil yet the exhaust system is coated like an oil burner.  Thank you for sending the gaskets Barry R. I will be ordering a couple of sets and paying you for the one that you sent.
« Last Edit: February 27, 2024, 03:44:58 PM by sixty9cobra »
6667fan
  • Every Second Counts
Re: Intake gaskets
« Reply #6 on: February 28, 2024, 08:42:14 AM »
Harry, how does the back side of number four intake valve look compared to the others? La Brea like?
Get stocked on utility blades for your gasket making class.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
sixty9cobra
Re: Intake gaskets
« Reply #7 on: February 28, 2024, 09:57:29 AM »
Backside looks ok front side is sucked in I can see the blue stripe about a half inch into the port. No sign of oil I guess it gets washed out or distributed everywhere when there’s high vacuum. I will pull the intake this week.exhaust is totally wet and back panel  of car has wet spots of oil.
Re: Intake gaskets
« Reply #8 on: February 28, 2024, 01:49:34 PM »
I had the same problem twice.i ended up using right stuff on the whole intake gasket!
