FE Technical Forum
Block bore
Topic: Block bore (Read 2249 times)
390owner
Full Member
Block bore
September 30, 2023, 06:29:33 PM »
Is this block toast. It has two rods that let go
IMG_7570
by
Daniel Crymes
, on Flickr
IMG_7571
by
Daniel Crymes
, on Flickr
IMG_7568
by
Daniel Crymes
, on Flickr
390owner
Full Member
Re: Block bore
Reply #1 on:
September 30, 2023, 08:16:34 PM »
Dont know what happened to my question Is this block any good. Two rods came loose and did this to the lower part of the bore on two cylinders It is a standard bore
Truth stands on its own merit.
Re: Block bore
Reply #2 on:
September 30, 2023, 08:55:55 PM »
Grind all the broken edges out smooth, and pressure test the block. If it pressure tests Ok, then it should be salvageable. Joe-JDC
390owner
Full Member
Re: Block bore
Reply #3 on:
October 01, 2023, 06:07:43 AM »
Ok thanks
FE Technical Forum
Block bore
