Author Topic: 1969 Torino,Fairlane,ranchero FE 4 speed conversion  (Read 2095 times)
djburton
« on: September 05, 2023, 01:48:24 PM »
For sale...most of the parts needed for a 4 speed conversion. All parts came from the same 69 Torino S code April build car. The car took a bad side swipe and has been parked since the middle 70s. It had actual 50k miles. The trans was excellent when disassembled, needed nothing but seals and gaskets.No wear on any rods or lever holes,all original hardware. The bell and block plate have some pitting on the bottom edge,inside only on the bell and not seen. Shifter was disassembled,detailed,new spring installed, handle is decent,some pitting on the bottom which would be covered by the boot.I could go on...lot of stuff here. Take a look. Everything is ready to install,really nice.No paint on anything that wasn't painted originally. I would like to sell everything as a lot and will ship at buyer's expense in one crate on a pallet but prefer pickup from 51103. Be easier for me and price will reflect that. Looking to get $3500 but will consider offers.  Thanks!
Toploader RUG C2,close ratio
Original shifter with handle,original backup light switch that works
FE Z bell housing and clutch fork,all threads good,no wear on pivot
Pedal assembly,swing bushings and holes perfect,working original brake light switch
Clutch release lever and rods,bronze bushings,frame bracket a little rough but usable,missing block bracket and push rod
Flywheel,resurfaced,new ring gear
Floor shift steering column,mounting brackets,original working signal switch,very nice wheel pad
Trans cross member,all rust chemically removed.
Mirror 105 block,tested,crank,rods,all standard,other engine parts
Richmond 4:33 9 inch gear set. USA made. Maybe 200 miles. Just throwing this in,too tall for what I was doing
Pictures to follow when I figure out how to post them.
djburton
Re: 1969 Torino,Fairlane,ranchero FE 4 speed conversion
« Reply #1 on: September 06, 2023, 07:13:33 AM »
More pictures
Mr Woodys Garage
« Reply #2 on: September 11, 2023, 03:57:34 PM »
Please Check Your Messages, And Give Me A Call. I'm Interested In This Complete Package. Pat Woody 515-556-6484
« Last Edit: September 11, 2023, 04:03:31 PM by Mr Woodys Garage »
