Author Topic: Lykins Motorsports 496ci w/ Weber Induction  (Read 5232 times)
« on: September 03, 2023, 06:53:52 AM »
Performance Summary:
      Cubic Inches:  496             Dyno brand: Stuska
      Power Adder:  Nope            Where dynoed: Dale Meers Racing Engines
      Peak Horsepower: 603 @ 5400
      Peak Torque:  640 @ 4800
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Robert Pond Motorsports cast iron, 4.310" bore
   Crankshaft brand, cast or forged, stroke, journal size:  Steel Scat 4.250"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar 6.700"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Racetec w/ Calico coated skirts, 10.7:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Clevite main/rod
   Piston rings brand, size, other notes: Total Seal, 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  Melling M57HV
   Oil pan, windage tray, oil filter adapter:  Factory deep sump, fitted with trap door system, new replacement oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports hydraulic roller
   Lifters brand, type:  Morel, standard travel
   Timing chain and timing cover:  Factory timing cover, Cloyes billet
   Cylinder heads brand, material, port and chamber information:  Trick Flow, out of the box, disassembled, measured, reassembled
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  2.190", 11/32"
   Exhaust valve brand, head size, stem size:  1.625", 11/32"
   Valve springs brand, part number, specs:
   Retainers and locks brand, part number, specs:
   Rocker arm brand, type (adjustable or non-adj), material, ratio: Lykins Motorsports non-adjustable, POP shafts, stands
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Custom Trend, 5/16", .105" wall
   Valve covers, brand, type:  Chrome PBF
   Distributor brand, advance curve information:  MSD w/ black cap
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Edelbrock
   Intake manifold brand, material, porting information:  Blue Thunder Weber
   Carburetor(s) brand, type:  Weber 48 IDA
   Exhaust manifolds or headers brand, type:  Dyno headers
Re: Lykins Motorsports 496ci w/ Weber Induction
« Reply #1 on: September 03, 2023, 06:57:41 AM »
We always seem to say, "There's more left in it" but this time I think it would be very appropriate to say that.  A/F ratios at WOT were 14-14.5 and I had no parts to swap to change the ratios with...
« Last Edit: September 03, 2023, 07:05:22 AM by blykins »
« Reply #2 on: September 03, 2023, 08:15:38 AM »
That's an excellent torque number, reflecting the IR intake.  Certainly more power and torque would have been available with a jet change, but I think HP would have been limited by the size of the carbs.  Those 48 IDAs just don't flow enough air to get much past 600 HP.  I wish that 58 IDAs would be more readily available, they would make a big difference.
« Reply #3 on: October 07, 2023, 06:50:20 AM »
Well done
« Reply #4 on: October 07, 2023, 08:36:00 AM »
Nice Brent heading for a Cobra?
« Reply #5 on: October 10, 2023, 10:47:53 AM »
'69 Mustang
