Author Topic: Bullock's Power Service - 429 cid iron head center oiler - pump gas 439 @ 5600  (Read 4389 times)
Performance Summary:
      Cubic Inches:  429             Dyno brand: Stuska
      Power Adder:  N/A             Where dynoed:  Dale Meers Racing, Buffalo, KY
      Peak Horsepower:  439 @ 5600
      Peak Torque:  471 @ 4300
Engine Specifications:
   Block brand, material, finished bore size, other notes:  C3 center oiler, 4.25 bore, squared, aligned, torque plate honed
   Crankshaft brand, cast or forged, stroke, journal size: Factory cast 3.78
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  SCAT H beam 6.49
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Diamond forged, 14 cc dish, 9.95:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite rod and FM main bearings, Durabond cam bearings
   Piston rings brand, size, other notes: Hastings 1/16, 3/18 standard tension
   Oil Pump, pickup, and drive:  Melling M57HV, Kevko pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Kevko deep pan, no tray, truck adapter (customer did not have one, just for dyno)
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Customer supplied, early Isky single pattern solid flat, measured at 274 adv, 236 @ .050, .525 lift, 108 LSA on 104.5
   Lifters brand, type:  Customer supplied solid flat (SBF design)
   Timing chain and timing cover: Cloyes 9 position, factory timing cover
   Cylinder heads brand, material, port and chamber information:  C3 low riser, Rev 3/8 valves, no port work, Viton seals, cups
   Valve springs: Customer supplied Isky, unknown part number, 125/300
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Factory 427 adjustable, no stands, no studs, with long finger tins
   Rocker shafts and stands, brand, material:  factory
   Pushrods brand, type, length:  factory
   Valve covers, brand, type:   427 baldy
   Distributor brand, advance curve information:  Pertronix 3, factory look alike, 38 total
   Harmonic balancer brand:  Aftermarket,427 copy
   Water pump brand, type (mechanical or electric):   Stock replacement iron  - electric powered on dyno
   Intake manifold brand, material, porting information:  Blue Thunder medium riser dual quad- unported
   Carburetor(s) brand, type:  C3 factory low riser carbs, rebuilt by Drew, progressive, vac secondaries left to function normally (not zip tied)
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: August 13, 2023, 08:34:26 AM by My427stang »
This one was a fun one one to build, less fun to dyno (only because of the weather giving us a 99 degree dyno cell for the second engine, a spring change and a new valve spring compressor that was made incorrectly.  It turned out to be a sweaty but uneventful afternoon)
It was originally planned to be a 429 inch, custom cam, Trick Flow medium riser 2x4 with all the tricks.  However, the owner decided to keep it more true to form, and it became basically a blueprinted  pump gas 427 than can be driven anywhere,  All good and new parts, even the NOS Isky cam, but just a different approach, refreshing to do a mostly original one.  The nice thing is, even with a very streetable cam and compression,  it out performed Fords original rating.
This one would be a sweetheart in a street Galaxie rowing a 4 speed, I think the owner may sell ultimtely though, trying to thin his herd of very nice cars and engines
galaxie
Great build!! With only changing to a 428 crank and everything else staying the same what power increase would you expect to see?
Thanks Brian
439/429 =1.02331 x 451.69 = 462.22ish hp.     Joe-JDC
Thanks Brian
IMHO the next area of improvement, without porting, would be the cam, 8 degrees of exhaust duration and increasing lift on both sides would have been beneficial on this or a stroker.  This Isky is a very nice running cam but it is old tech and doesn't take the head flow into account
The real benefit would be a head work or a better set of heads.  I have no doubt our original plan, TFS heads and a modern cam grind, would have gained over 100 HP with no changes to the rotating assembly, even more with cubes
