Author Topic: 482" FE Stroker, 582 HP, 581 Torque  (Read 15287 times)
« on: August 07, 2023, 09:53:15 AM »
Performance Summary:
      Cubic Inches:  482             Dyno brand:  Superflow 901
      Power Adder:   No            Where dynoed:  FE Power
      Peak Horsepower:  582
      Peak Torque:  581
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Pond aluminum block, 4.25" bore
   Crankshaft brand, cast or forged, stroke, journal size:  Scat forged 4.25" stroke crank, BBC journals
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar 6.700" BBC rods
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Mahle forged pistons, 11:1 compression
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Federal Mogul 351C 3/4 groove bearings, Clevite CB743 Rod Bearings .001 undersize, Durabond cam bearings for side oiler
   Piston rings brand, size, other notes:  Mahle thin rings, came with pistons
   Oil Pump, pickup, and drive:  Precision Oil Pumps HV pump, pickup for Cobra Pan, Precision Oil Pumps drive
   Oil pan, windage tray, oil filter adapter:  Cobra pan, Ford windage tray, Ford oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050")  Comp Cams hydraulic roller cam from Lykins Motorsports, 299/305, 243/252@.050, .610/.603
   Lifters brand, type:  Morel hydraulic rollers, standard (not short travel)
   Timing chain and timing cover:  Cloyes billet timing chain set, FE Power timing cover
   Cylinder heads brand, material, port and chamber information:  Trick Flow heads, out of the box, no porting
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Harlan Sharp rocker arm package, adjustable, stock ratio
   Pushrods brand, type, length:  Trend ball-cup pushrods, 3/8"
   Valve covers, brand, type:  Cal Custom, vintage
   Distributor brand, advance curve information:  Ford distributor with Pertronix, advance all in at 3600
   Harmonic balancer brand:  Professional Products
   Water pump brand, type (mechanical or electric):  Edelbrock mechanical
   Intake manifold brand, material, porting information:  Ford tunnel wedge intake
   Carburetor(s) brand, type:  Ford Holley carbs, 650 cfm, AC/AD (I think)
   Exhaust manifolds or headers brand, type:  Hooker competition plus
I have a local friend with a 57 Ford that has been equipped with a 428 forever.  He has been looking to upgrade the engine package so he came to me to help put it together.  This has turned out to be a long project, because of block availability.  We waited for over a year to get a BBM block and never could get one, so this spring he decided to go forward with a Pond aluminum block for this engine.
At the machine shop the Pond block required pretty much all the finish machining, including align honing the main saddle and cam bearing bores, and sizing the lifter galleries.  Once that was finished we were finally able to get going on the assembly, with the parts specified above.  This was my first experience with Trick Flow heads, and I must say I was impressed.  Looking at the intake ports, they get pretty small in cross sectional area inside the port, but the short turn is much improved over a stock or Edelbrock/BBM heads, and this showed up in the torque production.  The engine went together without too much trouble, although the block did require 351C main bearings (FE main bearings wouldn't fit), and the connecting rods measure big on the big end with standard size bearings, so I had to go with .001" undersized bearings.
My friend wanted the engine to look more or less stock, so he had me paint the block and heads Ford dark blue.  Almost killed me to do that LOL!  Here's a picture of the completed engine:
We got the engine on the dyno this past weekend.  We were hoping for 600 HP but didn't quite get there.  However, we also didn't try some of the standard tricks, like spacers, and despite the high RPM nature of the tunnel wedge intake the torque curve was very impressive.  So, as a street car this thing is really going to work well.  We started off with 110 octane race fuel and sneaked up the timing curve and RPM range until we got to 33-34 total and just over 6000 RPM.  However, starting at about 6100 RPM, the engine power fell off a cliff.  Something with the valvetrain was going on there, and my suspicion is either the hydraulic rollers are pumping up and holding the intake valves off the seat, or the valve springs aren't up to the drill.  In any case we decided to limit future excursions to 6000 RPM.  Certainly 600HP would have been achievable at higher RPM, based on the known performance of the tunnel wedge intake.
I want to address an issue about dyno data here, because this engine provides a good example.  Most dynos and/or dyno operators will take advantage of the smoothing function available with the dyno curves.  This function will mathematically modify the dyno data to make the curves look smoother, taking out the normal ups and downs of the torque measurements.  Below I have posted two plots of the dyno results we got when running the engine to 6300 RPM.  The first curve is the actual dyno data, and the second curve is mathematically generated from the actual data using the dyno's smoothing function:
It is clear from the first chart that something fairly dramatic is happening to limit power in the engine after 6100 RPM.  But, from the second chart, not so much.  The curve looks smoother in the second chart, which is what most dyno customers want to see, but it is hiding a serious engine issue.  I've mentioned this before elsewhere, but I always use the actual dyno data, not a smoothed curve, because the smoothing tends to hide problems.
This was designed to be a pump gas engine, so after running on the race gas to get the carbs and ignition dialed in, we backed the timing down 6 degrees and put in some 91 octane non-oxygenated pump gas.  We ran the engine several times, sneaking up to 32 degrees total on timing, and the engine performed nearly as well as it did on race gas.  We could have put a couple more degrees in it, but we decided to stop at 32 total to stay conservative.  Here's a chart showing the comparison between the pump gas and the race gas:
The last thing we tried was to add the oval air cleaner.  This cost some power, but not as much as we were expecting it to:
Overall  a successful dyno session; the engine ran beautifully and it was on and off the dyno in a few hours.  Coming up tomorrow I am doing another one of these 482" engines, but with some old Ford heads and a factory 427 block.  Following that I will be running one of my engines, a 492" engine with ported Edelbrock heads and a solid roller cam, to go in my Fairlane Cobra.  It will be interesting to compare the outputs from all the different motors...
Re: 482" FE Stroker, 582 HP, 581 Torque
« Reply #1 on: August 07, 2023, 10:23:20 AM »
Just curious if the springs were cam specific or were they the springs that came on the heads. I see the cam came from Brent and he usually sees his hydraulic rollers rev pretty well. All in all nice motor. Without that fall off I think you would have seen your 600.
« Reply #2 on: August 07, 2023, 12:19:49 PM »
The springs were whatever came on the heads.  I believe Brent selected the cam with the springs in mind - Jay
« Reply #3 on: August 07, 2023, 05:25:38 PM »
Jay, we had a similar experience with the trick flow heads on the dyno. My 465" engine was dyno'd with cast iron heads first, some edelbrock heads, then trick flow. The trick flow heads fell off a cliff at 5900-6000. We knew however that the engine would pull to 6500 based on our previous head testing, so we stayed in it and you can see that the curve comes back around. The cam in my 465" is in the same ball park you're dealing with there, around .610" lift, duration is a bit less, solid roller. We searched around for almost 2 weeks thinking we were running into fuel delivery issues, valve float, that there had to be something going on. Never found a culprit.
We compared dyno data with a local friend that has a 492" FE with trick flow heads in his 69 Fairlane. His dyno curve fell off at 5800 and he figured that's where it gave up. I wish they would have pushed through it on the dyno to see if it behaved in the same nature ours did.
I believe if you talk to Brent/Ross about the Trick Flows they'll tell you cam selection is finicky with the heads.
Our testing was done on an inertia dyno rather than an engine brake dyno, so I believe some of the effects are more dramatic. What I mean is if the testing was done on an engine brake dyno, when it hit that rough patch at 6000, the dyno lets the engine rev up at the rate of 300 rpm/sec anyhow. On this inertia dyno, the engine had to fight through the dip in power production to keep building rpm.
« Reply #4 on: August 07, 2023, 05:58:07 PM »
Here's the data with the edelbrock heads for comparison purposes.
6667fan
  • Every Second Counts
« Reply #5 on: August 07, 2023, 06:24:33 PM »
Good stuff Jay. The explanation on smoothing vs actual is nice and all the overlaid graphings are a nice bonus
What is the LSA/ICL?
« Last Edit: August 07, 2023, 06:36:19 PM by 6667fan »
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #6 on: August 07, 2023, 06:26:31 PM »
I wouldn't say that the cam selection is finicky, they are like any other cylinder head, they just like what they like.  I had this cam ground for Jay for this combination, based off of my own dyno testing with the TFS heads.
For some reason, I have never seen these kinds of trends, at least not the dyno graph where it looks like a ski slope.  Typically, when we hit a hp peak rpm with a pull, we don't keep going, but I have never seen that steep of a drop off in 100 rpm or so.  As a matter of fact, I've got a couple of engines running TFS heads with standard travel Morels and hydraulic roller camshafts.  One guy shifts at 7000 rpm and the ET falls off if he goes below that.
With all that being said, a drop off like Jay showed with the "corrected" graph is not what I would really consider abnormal with that combination.  It's a large engine, with a smallish 175cc head, and a 243 @.050" intake duration camshaft.  It's a small cam.  Peaking at 6000-6100 rpm with that cam shows how well the cylinder heads actually work and shows lots of potential.
I'll have to look up and see what LSA I had it ground with.  It's good data.  I'd also be interested in the A/F ratios that Jay was seeing, along with oil temperatures.  Morel lifters can sometimes be picky about oil viscosity and oil temperatures.  They are assembled with a much tighter tolerance than some of the other lifters, so they won't work in every single circumstance.
Your data is also good data, Mike.  Good to see the out-of-the-box TFS heads showing similar hp and more torque than the $$$$$ Pro Port stuff.  The different heads may want slightly different cam specs, but it's nice to see those results.
« Reply #7 on: August 07, 2023, 08:28:48 PM »
ICL was 106, can't remember what the LSA was (my friend has the cam card now), but the cam was advanced a few degrees with the 106 intake centerline.
« Reply #8 on: August 07, 2023, 08:56:39 PM »
Mike, thanks for that data.  I'm surprised that a cylinder head could behave that way, especially with all the good results that the Trick Flow heads seem to be having.  In fact, Tony Fritz told me at the FE Race and Reunion last year that his engine made 800 HP with an out of the box set of Trick Flows.  Tony is a good guy and I believe him, but I wonder about the dyno he was using; 800 HP seems awfully optimistic.  His Maverick does run in the 9s, though.
When I see something like what happened with this engine on my dyno, I don't rev the engine any higher.  I kind of wish now that I had; the engine didn't sound bad or anything at 6300 RPM, it just quit making power.  If you look in my book at page 228, for the solid vs hydraulic lifter comparison on my 428CJ, you will see the same kind of behavior with a hydraulic lifter.  It looked the same on this engine, but based on your results maybe valvetrain isn't the issue.  On that particular engine, which I had in my Mach 1 for a while, I used to regularly shift at 6500.  The engine always sounded fine.  So I learned long ago that even if horsepower is decreasing, the engine is still making power and should still run to a higher RPM, barring some catastrophic situation (valves hitting the pistons, for example).
Brent, A/F logged by the O2 sensor ranged from 12.45:1 at 5000 to 12.69:1 at 6100 on the best pull.  From the built in A/F calculation on the dyno, where it is measured based on the airflow through the carbs and the fuel flow through the fuel turbines, it went from 13.24 @ 5000 to 12.48 at 6100.  It dipped down to 12.21 at one point, but overall it was in the ballpark.  On the one pull we made to 6300 it got noticeably richer, down to 11.62:1 at 6200.  The chart below shows the airflow through the carbs; note that the airflow is dropping pretty good at 6200 and 6300.
I think its interesting that the front carb used more air at first, and then the back carb took over.  The vacuum secondaries were tie wrapped to open as mechanicals, so its not a variation in opening of the secondaries.  Must have something to do with the intake manifold.
Unfortunately I don't have oil temp, because we didn't have a port to monitor that on this engine.  But I would expect it to be at least the same or higher than the water temp, which was around 155.
By the way, this is a very interesting discussion...
TurboChris
« Reply #9 on: August 07, 2023, 09:25:29 PM »
Great thread guys.
« Reply #10 on: August 07, 2023, 10:03:41 PM »
Do you have a link for your back to back testing?
« Reply #11 on: August 08, 2023, 04:35:51 AM »
I don't have any back-to-back testing with TFS vs. Pro Port, but I was referring to Mike Brunson's discussion up above, where he did a back-to-back test of iron heads, Pro Ports, and TFS heads.  The results are up above in his graphs.
« Reply #12 on: August 08, 2023, 04:44:55 AM »
800 hp does seem pretty optimistic......  I've had a few approach 700 hp with out of the box heads, but an extra 100 hp is quite a bit.  It takes a LOT of FE on the dyno here to approach 800 hp.
LSA was 115 on this camshaft, I just looked back through notes.
It's also interesting on your air consumption graph that the two lines crossed at ~5200 rpm, just like HP and torque curves usually do.........interesting indeed.
Normally, when engines need to be leaned up, I get excited because that means the engine is efficient, but in this case, I'm not so certain on that.
Tunnelwedge
« Reply #13 on: August 08, 2023, 06:06:31 AM »
Interesting. I run basically the same engine except I use my home valve job BBM's.
482" Genesis block, Scat crank, Mahle pistons, similar size roller cam. Less compression.
The engine works awesome on the street. I have a 4 speed so the max torque is always ready.
I use some home made spacers for the carbs. The tiny flange of the Ford TW is why. The seal surface
is about a 1/4" on mine. I run it as a long distance engine and as a tow engine.
I cool it with a stock 1968 Mustang BB rad and small e fan with no shroud.
I use a small aluminum pully for over driving for the water pump.
I've run it with full electronic ignition and plain old points.
Runs the same either way.
It's been on the street now for 4 years.
I also have power brakes. Disc/drum I don't have any problem with the tiny Mustang booster
using the vacuum from the TW intake.
I mostly drive the engine on the highway at about 3000 rpm, the speed limit.
I does fine it town.
Get a good driveshaft and clamps.
« Reply #14 on: August 08, 2023, 06:49:28 AM »
Jay, we often ran our 10.90 door slammer (BBC, sorry) well past the power curve nearing the 1,320 finish line yet the car went faster and got a terrific top end charge. So yes, the power may drop off but it the e.t's and mph's were good, we'd still rev past the max h.p. level for our combo. I think many a drag racer do the same.
