FE Technical Forum
timing change
Topic: timing change (Read 2450 times)
timing change
July 24, 2023, 02:19:29 PM »
i changed from a msd box to a gm type module and now my timing is 3 degree higher 33 to 36 total.i have a msd distributor with the black bushing in it.question is ,do i change to the blue bushing or whatever color 3 degree is or do i just retard the timing 3 degree.i noticed the extra timing is making it hard to hot start.
1966 comet caliente 428 4 speed owned since 1983 1973 f250 ranger xlt 360 4 speed papaw bought new
GerryP
Re: timing change
Reply #1 on:
July 24, 2023, 03:42:53 PM »
That is common for it to pick up timing when changing to an HEI module. Roll your initial back to where it was.
6667fan
Every Second Counts
Re: timing change
Reply #2 on:
July 26, 2023, 07:30:32 AM »
After you pull 3* out of the initial what will your initial be at?
JB
67 Fairlane 500
482 cid 700/617
TFS Tunnel Wedge, BP BBM Heads, Bullet Custom Solid Roller, Ram adjustable clutch, Jerico 4-spd, Strange third member with Detroit Locker, 35 spline axles, 4.86
10.55@125.74 1.46 60’
1964Fastback
Full Member
Re: timing change
Reply #3 on:
July 26, 2023, 08:45:59 AM »
Don't the bushings just limit total advance? So if you switched bushings, I think it would still be 3 degrees advanced at idle but have less total mechanical timing. I agree - just set the initial back to where you had it.
Pat
Re: timing change
Reply #4 on:
July 27, 2023, 02:41:42 AM »
I get it now,my int was 15 total 33,now its int 18 total 36.if i back the int down to 15 again the rest will be back where it was at.i dont know why but i was thinking the bushing was the int instead of how much it advances.
FE Technical Forum
timing change
