Author Topic: New Cam and lifters Needed ASAP 427 Thunderbolt specs  (Read 2744 times)
Robin Hood
    • Acme Tackle Company
« on: July 07, 2023, 07:56:17 AM »
Hello all I am in need of a new cam and lifters for my 427 thunderbolt high riser. Does anybody know where you can get a brand new one? It seems like there is no availability
I am looking for as close to spec as possible
428kidd
Re: New Cam and lifters Needed ASAP 427 Thunderbolt specs
« Reply #1 on: July 07, 2023, 08:02:26 AM »
Alot of people are out of cores, Bullet did have some cores some time back, but not sure now. Why are you needing just cam and lifters did you have a failure?
Robin Hood
« Reply #2 on: July 07, 2023, 08:27:37 AM »
The car had sat for many years and not sure if the cam had ever been broke in properly. running poorly and two lifter/lobes were scored real bad.
So, out came the engine and total clean and hone etc.
Need the cam or cant put the car back together....... :'(
« Reply #3 on: July 07, 2023, 01:15:17 PM »
Is there some reason to want an original? The C8AX-D was the 'Cat's PJs' a long time ago, but cam design now is so far ahead that there is, literally, no reasonable comparison.
« Reply #4 on: July 07, 2023, 06:14:38 PM »
Got plenty of flat tappet cores available.
preaction
« Reply #5 on: July 07, 2023, 11:03:59 PM »
Try a bit more clarity about exactly what you want, your saying a few different things that do not add up to any one.
« Reply #6 on: July 08, 2023, 12:12:42 PM »
If interested, PM me, I have a customer with an original 427 D cam that did a basic clean up grind by Oregon cams , I can share his info
It was already broken in, dumbell  lifters are with it and boxed in order, just going a different route with the engine
